1973 4 speed GTO
On the Bay.. A board member owns this car. Featured in Hemmings Muscle Machines. I have seen this car several times, and its great example.
http://cgi.ebay.com/ebaymotors/1973-...72f43708#v4-43
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Thank you, Sir!!
Very nice. The enine compartment is immaculate.
72 TA 4 speed 76 TA auto father/son project |
Nice rare car!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
I see it's developing the usual bubbles under the vinyl top...mine did the same thing...the factory just did no prep or sealing to the roof on cars getting a vinyl top.
Also, what's up with the nose filler between the nose and the bumper? Looks like it doesn't fit proper in the center.
Another one:
http://cgi.ebay.com/ebaymotors/1973-...item4602be9ced ROUGH is the word for this one. This one would need a solid donor car to bring it back.. Quote:
And all that "roughness" is just what is easy to see, imagine what is hidden??? And wow look at that current bid price and he has a reserve, he may want to take the money and run.
Wanted 1977 Can Am forgotten projects or parts cars, other 73-77 Pontiac A-bodys, also 4-speed setup for 73-77 GTO, Grand Ams, CA e-mail me shubedo1@yahoo.com with info. Buy Sell or Trade -------------------------------------- |
He is referring to the reverse lockout mechanism that usually got removed when an aftermarket Hurst shifter was installed. It's mounted of left side frame rail.
73 Grand Am 455 Muncie M20 4 speed 3.23 gears |
Pete, that makes sense. When I bought my GTO, the reverse lockout/ backup lamps were inoperative. All of the parts were present except for the rod that joined the reverse lever on the much superior replacement Hurst shifter to the mechanism on the frame. I modified a F body rod, and it works perfectly, and looks 100 percent factory.
2 years ago I lucked out and bought a brand new in box original ITM shifter for my Grand Am. Must have been in the box for 30 years. Have to pull up on lever to get into reverse. I know Hurst are great shifters, no question about that. However, this ITM shifter has a perfect throw and shifts like slicing through butter. The reason why people removed the reverse lockout when a Hurst was installed was because the factory shifter levers would not fit on the Hurst shifter. The original reverse shift lever was longer and had an extra hole on bottom. The bottom hole is where the reverse rod was mounted. When car was shifted into reverse to back up or to remove the key from the ignition, this reverse rod was moved, causing the swivel to turn,causing the upper rod connected to the steering column to move. Pretty simple design. On a side note, I should be getting my 455 from the rebuilder soon. Can't wait until I drive this Grand Am with the 455.
Should be a lot of fun, Pete!
SOLD for $1643.. a good price for a complete 4 speed setup, then part/scrap the rest.
Sold for $14,000.
To a board member? Wonder if I will see it at Carlisle again?
Lives in CT, so Carlisle might not be in the future, but he plans on going to local and regional POCI meets with the goat.
Anybody notice the 70-72 custom sport wheel in the blue car? Whats up with that? The white car had the later custom sport wheel in it.
And the main reason the reverse back-drive control rod was removed was to install headers!
Jeff Ianitello |
Most 1973 GTO's have the 1970-72 Custom Sport wheel if optioned that way. It was one of the very few carryovers from the previous generation.
interesting. Why so, if the grand am and gp got the new one? I guess they wanted to delete the old stock of the other wheels? HAHA!
Jeff Ianitello |
Don't know the reasoning. None of the GP's or GA's received the small hub Sport wheel.
