Old 04-19-2012, 07:19 PM
sphynx88 sphynx88 is offline
Default Valve Spring Brake Booster intereference
I got 15 valve springs done today (putting the inner spring back in after cam break in), the one I have having trouble with is the exhaust on #7. I am running into the brake booster and there is no feasible way (using a star handled valve spring removal tool) to get it off. Any other ideas?
I am using the rope trick in the cylinders.
Old 04-19-2012, 07:47 PM
grivera's Avatar
grivera grivera is offline
This type of tool worked good for me in my FB. The brake booster wasn't even an issue...
http://www.amazon.com/Powerbuilt-648...6&sr=8-1-spell
Will Rivera
Old 04-19-2012, 09:33 PM
cutlas cutlas is offline
Same tool I used on my 67 FB.
1967 Firebird project in the works
400, 670 heads, 2802 cam, Hooker comp, Crosswind intake, Quadrajet, 700r4, 3.42 Posi.
Old 04-19-2012, 09:39 PM
FrankieT/A's Avatar
That tool works great! Blows away the star tool in everyway. It's usually available at any part store. Cheap!
Old 04-21-2012, 02:49 AM
lust4speed's Avatar
You can also take the brake booster/master cylinder off the firewall without disconnecting any lines and set it out of the way.
Mick Batson
