Old 05-06-2012, 08:21 PM
Mechanic No. 4 Mechanic No. 4 is offline
Default 8 BOLT WATER PUMP QUESTION
Hi guys, Going to remove my water pump and check impeller clearance this summer. Don't know if I will find a stamped or cast impeller on the pump. I understand if it is a stamped impeller, I should replace it with a pump that has a cast impeller. I know Cardone has made efforts with this problem but are all the Cardone Select New pumps that I can currently buy up to speed? Would I be better off buying a Flowcooler 8 bolt waterpump from our sponsor? I'm not trying to "cheap out" here, just want to do the job once. Thanks in advance for your help!
Old 05-07-2012, 07:37 PM
R68GTO's Avatar
R68GTO R68GTO is offline
I would purchase a cast impellar pump. The key is the clearance.
R68GTO
1969 Camaro COPO 427 "RAT'S NEST"
Old 05-07-2012, 09:21 PM
Do you know if all the new Cardone pumps have cast impellers? I hear that Cardone is the brand to buy.
Old 05-08-2012, 08:40 PM
R68GTO's Avatar
I don't know. I just went to the local auto parts store and had the guy bring out rebuilt pumps until he brought one with a cast impellar.
R68GTO
