Old 05-14-2012, 03:54 PM
666 the legend's Avatar
666 the legend 666 the legend is offline
Default 72 interior door handle screws??
.. what kind of screws hold the interior door handles on..?? I cant find any info anywhere..
Old 05-14-2012, 04:05 PM
also....What kind of screws go into the map pocket...the[2]..that go straight down..Are they the chrome finish washer..?? or are they just a bugle head without the washer..??
Old 05-14-2012, 06:30 PM
78w72 78w72 is offline
there are 2 5/16" head screws behind the plastic cover plate that covers the handle.
the map pocket uses 2 non washer 5/16" screws, like what holds the gauges in the dash, only shorter.
Old 05-14-2012, 06:43 PM
are they a No-3 Phillips head screw..??[ door handle]..
Old 05-14-2012, 06:57 PM
not on the 70-74 cars i have seen, but the 72 & 74 i own have a hex head bolt, 5/16" size. only because i just removed the 74's door panels a couple days ago do i remember what they were. no phillps head screws are used on the map pocket or the door handles. the chrome screws, sometimes with washers, are usually for plastic interior trim like sail panels etc.
Old 05-15-2012, 10:10 PM
TA455HO's Avatar
TA455HO TA455HO is offline
When you say interior door handles are you refering to the items in these pictures?
Standard interior
Deluxe interior
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 05-16-2012, 12:43 AM
TA455HO's Avatar
If so, here's what ones off my 1971 look like. 5/16" hex head per previous post. Captured washer. Total length of approximately 5/8". The washer is about 1/2" diameter.
Old 05-16-2012, 11:18 AM
..I went through every old nut and bolt I have for the car and couldnt find 'em.....I eventually put some new bolts in there..But now after these pics..I DEFINITLY did not have those layin around.....Thanks guys...the car is almost done....couple more weeks I hope.....so Ill have more Knit Pickin questions I m sure.......Its amazing how much time the lil things take .I just ordered more parts last night.....
