Old 05-17-2012, 10:39 AM
Erik_H's Avatar
Erik_H Erik_H is offline
Default need diagnosis help with engine noise
I have no experience in diagnosing noises, so I hope someone can figure this out. From inside the car it sounds like halfway between a flutter and a rattle. The video I took with my phone with the window open makes it sound a lot more like a rattle but that's not as bad as it sounds in real life. The sound does not happen at idle or cruise, but only on acceleration. At first I thought it might be an exhaust leak, and then I started to get worried about a valvetrain problem or worse detonation. Like I said, I really don't know the difference between those sounds so I'm at a loss. Anyway, here's the video - please let me know what you think.
Sorry - having problems uploading the video.
Last edited by Erik_H; 05-17-2012 at 11:42 AM. Reason: can't upload video properly
Old 05-17-2012, 12:15 PM
73 bird 73 bird is offline
What engine and heads do you have? What is the compression?
73 firebird 455 6x-4 heads 350 turbo 3.73 gears
1/8 7.65 @ 90.95
1/4 11.96 @ 112.60
new best in 1/8th 7.57@91 mph(4-13-12)
Old 05-17-2012, 03:56 PM
GoatDr GoatDr is offline
First thing, check your flywheel/converter bolts.
GoatDr
Old 05-18-2012, 06:03 AM
steve25 steve25 is offline
Did the noise start on its own, or after you did some work on the car?
Old 05-18-2012, 10:29 AM
Erik_H's Avatar
It's a TKO so there are no converter bolts. Dumb question, but is it typical for the same issue to happen with the pressure plate and/or flywheel bolts? I'd have to drop the trans to retighten all of these obviously which is a pain to do in the driveway.
The noise started on its own. I have done lots of things to the car, but the only engine related things have been timing and carb tuning, and an intake swap so I'm not sure I caused the noise. Anything is possible though, I do have a tendency to fix one thing and mess up another.
The engine is the original 350 with a PPR stroker kit, KRE heads, I think the compression is around 10-10.5:1. I'm going out there again to try to get a video of the noise.
Old 05-18-2012, 04:28 PM
Erik_H's Avatar
Got the video to work. Please give it a listen and let me know what you think it might be. Thanks.
http://www.youtube.com/watch?v=kFQ41...ature=youtu.be
Old 05-18-2012, 04:32 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Almost sounds like a rocker arm or lifter related to me.
Or maybe even exhaust leak?
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 05-18-2012, 04:57 PM
428GTO70's Avatar
Forgot to mention, I started out this spring by getting a similar problem in my car...it ended up being a blown head gasket between cylinders 4 and 6. Didnt lose any coolant it was just between the cylinders. I even posted a topic that is eerily similarly titles to yours:
http://forums.maxperformanceinc.com/...d.php?t=695593
Old 05-19-2012, 01:48 PM
Erik_H's Avatar
interesting, I'll have to do a compression check.
Old 05-19-2012, 01:55 PM
Erik_H's Avatar
OK, I'm now wondering if a different issue is related or not. Starting out of nowhere just last week, I am having very violent bucking when I hit the accelerator in any gear. If I'm very smooth and light it is fine, but if I step on it it really has problems. Idles fine and revs up in neutral fine, it only happens under load. If there is indeed a head gasket issue like 428GTO70 found, would these things all be related? I can live with the minor noise, but this bucking and jerking is really bad.
Old 05-19-2012, 04:14 PM
428GTO70's Avatar
Hmm not sure what that could be, but I guess you could start with the suggestions I got in my thread. check plugs wires cap rotor and advance weights/springs under the cap. Could jump straight to a compression check while you have the plugs out. Hopefully yours is an easy fix. Bucking could possibly be fuel related i suppose also.
Old 05-19-2012, 09:12 PM
GT182's Avatar
GT182 GT182 is offline
Eric, it could be the the coil cutting out under acceleration. Had that problem with my coil for the points distributor. Switched to HEI and problem solved.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 05-20-2012, 09:50 AM
02Hawk's Avatar
02Hawk 02Hawk is offline
sounds like a lean condition or detonation What is the timing set at? back it off a bit to see if the noise stops
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 05-20-2012, 07:34 PM
Erik_H's Avatar
Yeah, you know I was having ignition issues recently. I had to change out a bad MSD box last month. I also changed out the coil, rotor, and cap while I was at it since the contacts all looked a little burned. It's an HEI from Ace at PPR. It's a Chinese no name piece, but Ace says that they have been reliable and he uses lots of them. The only other things I could change are the plug wires and the plugs. Might be worth a try since they're relatively cheap.
It seems like the 2 problems are probably unrelated. I want to fix the bucking and jerking first as it makes driving really irritating and probably isn't doing the driveline any favors either. The fluttering/tapping/whatever sound will be next. I will back the tining down a little to see if it goes away though. It's at about 14 right now, maybe that's too much. The distributor is supposed to have 21 mechanical. Take that plus the vacuum advance and maybe it's just too far, I don't know. Should I back off the vacuum advance first? I would think that 35 total is just fine isn't it?
Old 05-21-2012, 10:51 AM
02Hawk's Avatar
l have a 541 that likes 35 to 36 but more thanthat its on the edge. i have another 455 in the Judge (iron heads) that is content at 31 to 32 degrees......what are the engines temps when the noise is occuring?
i also noticed you are running a hyd roller. What distributer gear do you have on your combo?.....also how much vacuum are you making? maybe your holly system is not getting a good reading and its affecting the AFR readings causing the system to go lean?
Just more crap to check
Old 05-23-2012, 01:57 PM
Erik_H's Avatar
OK, I fixed the bucking issue. Turns out that when I put in the new 6AL box, I ran the green/purple wires with the others to the HEI. They have to be separated according to MSD because of EMI. Moved them apart 4-5 inches and all is well again.
Still having the other noise. I'm thinking it's either a header leak or rocker arms need to be relashed/adjusted. I'll post back on that when I get under the hood again.
Old 06-20-2012, 08:33 PM
Erik_H's Avatar
Revisiting this again. I took the vacuum advance hose off of the carb and plugged the port. Drove it to dinner, about 20 minutes. I did not get the noise anymore which was good, but the idle dropped about 500 rpm and the water temp went up 15-20 degrees. Would someone tell me what this means?
Old 06-21-2012, 07:15 AM
grandville455's Avatar
grandville455 grandville455 is offline
Sound's like the vac can is giving it too much advance and its pinging badly? I would limit it down to arount 10-14 degrees, so you end up around 40-44 total
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 06-23-2012, 06:12 PM
Erik_H's Avatar
Damn! I snipped a razor blade to size and super glued it to the vacuum advance according to advice on threads here so that the upturned arm can only travel 1/8" under vacuum. I was hoping this would get rid of my noise, but it didn't. I guess it was still a good idea, but back to the drawing board for me on this noise. I'm starting to wonder if it's not just some random metallic rattle or vibration. Whatever it is, it's driving me nuts. Anyone have any other ideas? I've got a dial back light on order that also measures RPM, so I'm going to write down all the specs of the mechanical advance curve and post them. Maybe that will mean something.
As an aside, while in the distributor I noticed that the button had melted itself into the cap. Tons of reading here explained it to me, but it seems there are strong disagreements as to how to solve it. I'm also ordering the low resistance button from MSD and a new cap. If that one melts, it's on to an external coil.
Old 06-23-2012, 06:36 PM
Bluesugar Bluesugar is offline
Your exhaust system might be toast in the muffler baffle area(rusted out,banging around in there,popping),..how old are those mufflers?..They can restrict power and clog up everything including your brain!!
