Old 05-26-2012, 07:30 PM
Velox65's Avatar
Velox65 Velox65 is offline
Send a message via AIM to Velox65 Send a message via MSN to Velox65 Send a message via Yahoo to Velox65
Default Turbo 350 issues
Hello all, I have a th-350 that I've had sitting around for a few years, when I got it I put a b&m shift kit and a 2300 stall, 2 days ago I finally got my car running and the trans in. Drove it for a few days and the passing gear would not work, today it suddenly worked however now it won't hold a gear if the engine Rpms are under 3000 it will just act like its going into neutral or search between them.
When it does go into gear it's nice and solid.
I'm at a lose, any ideas?
"The only Substitute for Cubic Inches is Cubic money"-My Father
"Never under estimate the power of a well calculated Ass-Kicking"
Our's is a world of nuclear giant's and ethical infant's, we know more about war than peace, more about killing than living.
Old 05-26-2012, 09:01 PM
stevep's Avatar
stevep stevep is offline
Are you sure that it is full of fluid??
Old 05-26-2012, 10:31 PM
Velox65's Avatar
Yea we stored it empty, filled it When we installed it and it's still topped up after this happened.
Old 05-26-2012, 11:13 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Full manifold vacuum to the modulator?......Cliff
Old 05-27-2012, 12:57 PM
Velox65's Avatar
Yea I checked it this morning it has full vacuum, now it won't go into any gear even at high rpms, replaced the kickdown and the modulator, didn't help. I guess I'll haul it to a tranny shop or swap it for a 4 speed setup
Old 05-28-2012, 09:47 PM
chiphead's Avatar
chiphead chiphead is offline
Is the fluid burnt? Any weird noises? Sounds like the clutches burned out. Do you know how the clutch packs were assembled, or if upgraded sprags were installed? This can also happen if the shift kit wasn't installed properly, or if the pickup filter falls off.
Old 05-28-2012, 09:51 PM
se428bandit's Avatar
se428bandit se428bandit is offline
Years ago my T/A wouldn't go into high gear in higher RPM's and found out the rubber vacuum line was sucking itself shut.
