Old 06-10-2012, 09:41 PM
ArticGTO ArticGTO is offline
Default Front drum brakes
Does anyone know where I could purchase new front brake drums for my 1970 GTO?
I do not want Chinese parts
Old 07-29-2012, 07:12 PM
HELLO ??!?!?!?
Old 07-29-2012, 08:05 PM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
a lot of people yank the original front drums and swap to disc, so check parts for sale here or post a wanted ad. you could also check Rock Auto.
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 07-30-2012, 09:26 AM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
X2.
Inline Tube should also have these.
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 07-30-2012, 03:22 PM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
If you're not in a hurry, I will be pulling mine off to install discs probably by the end of summer. You can have them for the cost shipping if you want.
Mitch Kunath
Old 08-12-2012, 01:38 AM
howthenotesbend's Avatar
howthenotesbend howthenotesbend is offline
If you have the extra money laying around then i would suggest buying a power disc kit from jegs, summit or ground up.... it makes all the difference in the world.
-Andrew
1969 el Camino SS 396
1970 LeMans Sport 350
2000 Camaro 3.8
Old 08-13-2012, 08:04 PM
Thumbs up
Thanks so much everyone for your ideas and advice!!
I decided to install a disk brake kit instead of replacing front drums!!
I installed kit 2 weeks ago and do like it.
Only wondering if anyone else installed one of these kits with vacuum booster and master cylinder, spindles, calipers, hub, back plate etc...all at the same time?
What I noticed is the travel on the brake petal goes further down before any braking. Petal is firm, but have not slammed on brakes yet to check for sudden stops, wanted to brake in first.
Is there anything to check?
Old 08-14-2012, 12:38 AM
check your brake lines, did you replace them at all? bleed them?
i installed the kit in my el camino and it was funky at first but i changed the lines and bled them, it worked like a champ.
2000 Camaro 3.8
Old 08-14-2012, 10:27 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Also check the rear shoes to make sure they're properly adjusted . . .
Regards,
"455HO" Lloyd
Old 08-14-2012, 11:20 AM
Sirrotica's Avatar
X2 on the rear brake adjustment, makes a huge difference if there is too much clearance between drum and shoes.
Also look at the rear brake hose, many times they look fine from the outside and they fracture inside and swell upon application causing low pedal.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-14-2012, 07:37 PM
Thanks!! I'll check the rear brakes and hoses and bleed lines and get back to all
