Old 06-25-2012, 03:53 PM
70 Rick's Avatar
70 Rick 70 Rick is offline
Default Paint for inside panels
Hi guys,
What are you using to paint the inside of front fenders, hood, etc.? I was considering the black DP primer, but I was advised to topcoat that with a urethane for extra protection. Then, I would have to add a dulling agent, which seems overly complicated. Is there anything in a one-step process? I am kinda curious about that Kirker hot rod black.
Visit my GTO blog at: http://www.mycardinalred.com
Old 06-25-2012, 04:39 PM
70 Rick's Avatar
Just realized this should probably be in paint & bodywork, feel free to move my post Mr. administrator.
Old 06-27-2012, 12:10 AM
A.W.Dille A.W.Dille is offline
If you have a PPG jobber in your area they should have a formula for mixing the correct tone of Black for underhood use. In fact if they have a book of paint chips there should be a listing there where they can mix it for you.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 06-27-2012, 09:23 AM
tripower's Avatar
tripower tripower is offline
Originally Posted by 70 Rick View Post
Hi guys,
I have used PPG Omni line with a flattening agent with good results. Their top line stuff can not be flattened. You have to play around with the flattening agent to get it the right sheen of black.
Eastwood has lots of ready to spray blacks that you can buy to use in a spray gun.
Norm J
Old 06-27-2012, 12:33 PM
bigborehunter bigborehunter is offline
The inside of two front fenders I've seen on a car were dull gray. It was paint too.
Old 06-27-2012, 08:26 PM
If you decide to go with black, I've found that gloss black Rustoleum in the quart cans, reduced with a bit of Acetone sprays really nice and gives a nice semigloss sheen. It does not spray out glossy and it's very, very tough.....and cheap. The back of the can actually tells you how much acetone to add for spraying.
