73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 07-16-2012, 01:15 PM
pete315 pete315 is offline
Default clutch question
Before I drop in the rebuilt 455, I want to install a new clutch. The car weighs over 4000 lbs so I need a good one but I don't want to pay a fortune. What's a good brand name? Any good places online to buy one? Thanks
73 Grand Am 455 Muncie M20 4 speed 3.23 gears
Old 07-16-2012, 01:29 PM
triathlonx13's Avatar
I would not run a heavy car like yours with any rear gears lower then 3.42 and a manual transmission. The lower the gear the harder on that clutch.
I recommend Centerforce: http://www.jegs.com/i/Centerforce/183/DF271739/10002/-1
Another thing to recommend is that you have your flywheel resurfaced to ensure a fresh new surface and make sure to follow the brake in instructions... means everything!
I've had good luck with these and I'm sure there are other good options out there - but in my experience these work great.
Old 07-16-2012, 07:42 PM
77 Canamman's Avatar
Thumbs up
X2 on the Centerforce. I had one in my Plymouth and loved it.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 07-17-2012, 06:29 AM
X3 on the Centerforce Duel Friction.
But you must follow the break in instructions with them, I installed one in a freinds car a few years ago, and after about 50 miles he started doing bun outs with the car, and the clutch didn't last 1000 miles!!!!!!!! My 4600 lb Wagon has 3.23 gears and it works very nice in that car!!!!
Old 07-19-2012, 02:49 PM
I got 3.23 gears. I would like 3.42 but not sure how to swap out gears. That clutch looks nice but a little pricey. I can't remember ever doing a hole shot with this Grand Am and doubt I ever will. I'll have to shop around.
Old 07-19-2012, 08:22 PM
Don't put a cheap clutch in the car. You will not be satisfied. Also, do not forget to resurface the flywheel.
