Old 07-30-2012, 11:34 AM
hendoIV hendoIV is offline
Default RA IV heads 722
722 1969 Ram Air IV heads. Rebuilt and ready to bolt on. No porting. Most likely these were on a car in 69 as they don't have an X cast on them, like over the counter 722 heads do. $3,000 plus shipping.
PM with interest.
Old 07-31-2012, 08:54 AM
Photos of heads. Springs have 125 lb seat pressure. Along with a set of head bolts, believe to be ARP.
ID:	293021   Click image for larger version
Old 07-31-2012, 01:58 PM
devonrexwa devonrexwa is offline
I can't see the date codes in the pictures. Would you mind sharing. Also, do these have hardened valve seats installed or are these stock. Thanks.
Old 07-31-2012, 03:41 PM
comanchefirebird comanchefirebird is offline
There are no date codes on production 722 heads.
The dates when originally cast get milled off for the valves.
Old 07-31-2012, 05:06 PM
Correct, no date codes on 722 heads.
Stock valve set up, I believe.
Old 07-31-2012, 08:44 PM
The Boss's Avatar
The Boss The Boss is offline
Actually they got milled off when they drilled the center head bolt hole. In fact if you look closely at one you can see the oval shaped pad that was put in the mold - only the ends are left after the milling process.
And go racin' in the street.
Old 07-31-2012, 10:18 PM
Thanks for the replies. I guess I have only seen service replacement heads, which if I recall right, had the date code off to one side. I appreciate learning something new.
Old 08-07-2012, 09:43 AM
Heads have been sold. Thank you.
