Old 07-30-2012, 11:36 PM
Nor-Cal 70T/A's Avatar
Nor-Cal 70T/A Nor-Cal 70T/A is offline
Default 1970 Trunk Harness
I just received a new tail lamp harness from American Autowire and noticed it was supplied with black lamp sockets. My originals are an off-white/cream color.
I called them and they say their prints call for black sockets. I then called M&H, and they say they use black also.
I think they can add my originals to the new harness, but I might just refurbish the original.
I'm just curious what color you guys are seeing on yours....
-Larry
Old 07-31-2012, 12:09 AM
mslcar's Avatar
mslcar mslcar is offline
Mine are white/cream color
1970 Formula RAIII
Old 07-31-2012, 07:05 AM
GETRIDAONE's Avatar
GETRIDAONE GETRIDAONE is offline
I used the harness out of an early car, it was white. I think my other two later 70's had black sockets. It seems there might have been a change at some point.
Old 07-31-2012, 03:02 PM
Formulajones's Avatar
Mine are white. May built Van Nuys.
Old 07-31-2012, 06:35 PM
FunctionalShaker FunctionalShaker is offline
White. I had the same issue with the alternator connector -- the original is grey, theirs is white. They said a change in color has to do with the grade of plastic.
You can also pop the contacts out -- see pic -- and switch them, if they're the same. See pic. The screw driver points to the tab you have to push out of the way from the lamp side to pull the contact out.
Name:	Lamp socket.jpg
Old 07-31-2012, 09:23 PM
The Boss's Avatar
The Boss The Boss is offline
White here - if you need them I could probably pull it and send them to you.
And go racin' in the street.
Old 07-31-2012, 09:49 PM
Thanks for the replies. It looks like the white sockets are pretty common on 70's.
For the record my car was built April '70 @ Norwood.
Great info... I think I'll give this a try. Thanks.
Thanks for that offer, but I still have my old sockets and they look pretty decent.
-Larry
Old 08-01-2012, 12:36 AM
eaglesan13 eaglesan13 is online now
My April Norwood car has white sockets.
Old 09-29-2021, 12:24 PM
RamAirPwr RamAirPwr is offline
Reviving an old thread
Has anyone been able to source the white sockets? I've order some samples from various vendors over the last few months and none are close
Even the used sets on eBay have black sockets so guessing they had a short run before switching over in 70-71
Thanks for the help
1970 RAIII white/blue
Old 09-29-2021, 12:35 PM
jonra3 jonra3 is offline
My May of 70 car has the white sockets, try this part number on ebay, 8914823 there are some on ebay
Jon
Old 09-30-2021, 12:35 PM
Jon
Thanks Jon, I'll try that number
I was working off of 8914822 from the Pontiac parts manual
Old 10-04-2021, 10:33 PM
Unfortunately, socket 8914823 or 8914822 isn't close to what's on the car. First pic is from Bruce's earlier post with the square bottom, which is also on my harness
Any idea what that part number is?
ID:	574432   Click image for larger version
Old 10-05-2021, 05:10 PM
unruhjonny's Avatar
there is a 1970 Lemans in a local self serve yard;
want me to grab the white lamp sockets?
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 10-05-2021, 10:41 PM
That would be awesome!
PM sent
Old 10-06-2021, 03:21 PM
unruhjonny's Avatar
hmm;
well the sockets on this 1970 Lemans are the second type - not the square bottom;
I'm guessing that's a hard pass for you
1970 Formula 400
Old 10-06-2021, 03:22 PM
unruhjonny's Avatar
another angle (uploading directly from phone, hense single image attachments)
1970 Formula 400
Old 10-06-2021, 04:02 PM
hmm;
Yes, but thanks for taking the time to look...very much appreciated!
Old 10-06-2021, 04:23 PM
Cool
I may have a second harness with the sockets you need, I am looking for my original harness and my extra one, both are white. I started my 70 TA restoration, again, so I have a few boxes to look through.
I will keep you posted.
Jon
Old 10-06-2021, 04:46 PM
unruhjonny's Avatar
no problem.
At least we know that Oshawa built cars, assembled in October 1969 had the wrong lamp sockets for you.
1970 Formula 400
Old 10-07-2021, 01:50 PM
Jon
Thanks Jon!
