Old 08-14-2012, 08:50 AM
zman1969's Avatar
zman1969 zman1969 is offline
Default 79-81 T/A rear disc brake caliper brackets
I have a pair of rear disc backing plates or cliper brackets off a rear end I bought no other parts. looking for $40 for the pair plus shipping- include 8 mounting bolts
were off a Texas car and are not pitted - should clean up nice
please email me for pics [email protected] as I am not on this board very often
thanks PY!
Old 08-14-2012, 12:40 PM
takid455 takid455 is offline
Send a message via AIM to takid455
Default backing plates
EMAIL SENT ON THE BACKING PLATES
Old 08-15-2012, 07:30 PM
zman1969's Avatar
still available
these do fit in large flat rate box that's 15$ to ship - how about 50$ shipped for these
Paypal is accepted
Old 09-24-2012, 09:28 PM
BAD2000TA BAD2000TA is offline
Originally Posted by zman1969 View Post
still available
Paypal is accepted
Still got 'em?
2001 Pontiac Trans Am WS6, 6-Speed, LS6 block, TEA LS6 heads, 4" SCAT forged crank, SCAT H-Beam rods, 226/234 cam, McLeod RST clutch, SLP Lid, SLP Power Flo Catback
1980 Pontiac Trans Am Y-84 Bandit WS6, 455 (.030 over), #96 Heads, Hedman headers, Wolverine 234/244 cam, Performer intake, Holley Sniper
"Need a car to run blocker. Speedy car. Speedier than that....."
Old 12-04-2012, 09:35 AM
zman1969's Avatar
Default caliper brackets
first set is sold now i have just picked up another set last saturday
these have some rust on them but not bad
50$ shipped
please email me at [email protected] as I am not on this board very often
Old 12-26-2012, 11:16 AM
zman1969's Avatar
bumping up who wants rear disc brakes?
Old 12-26-2012, 06:05 PM
ITSAV6 ITSAV6 is offline
what years of the 2nd gen F body rears do they fit? (I know 79-81)
67 Aquamarine vert,matching int,400/335,4spd,posi w/411:1,headers,Edelbrock P4B,hurst shifter. Starting resto soon
Old 12-29-2012, 11:05 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Brackets will fit any 10 or 12 bolt housing for a second gen probably even most A bodies but have staggered calipers to clear the staggered shocks on the TAs. Need a 2.75" distance from axle flange to rear end flange. I;ve got a set on a 12 bolt with weld on ends from Moser.
Skip Fix
Old 04-02-2014, 01:34 PM
zman1969's Avatar
Default more brake brackets
I have another set of rear disc brackets I bought when I was in Phx visiting mom, these are pitted and not the prettiest but will work just fine I even tapped caliper threads out because calipers were long gone
I can text pics later if needed, email or text 469 two three three 7142
thanks 45$ shipped
Old 04-02-2014, 05:24 PM
CAn you post some pics on here so we can see what were buying ,, Thanks Rex.
Old 04-01-2015, 01:26 PM
zman1969's Avatar
old thread, another pair of caliper brackets available 50$ shipped
I have pics on my cell text if you would like to see them
469-233-7142
Old 04-02-2015, 07:15 AM
Kent Christensen's Avatar
Kent Christensen Kent Christensen is offline
Default Disc Brakes
I am looking for what ever the e-brake cables hook to at the back of the disc brakes. I am working on a 80 T/A and the cables are just hanging there with nothing to hook them up to. If you have the parts that would be great.
Old 04-02-2015, 11:20 AM
zman1969's Avatar
sorry Kent there are brackets and spings to mount the cables to a lever on the actuating calipers. heres a picture of what cable looks like attached to the caliper
I dont have any of this
just the caliper brackets and bolts
Old 06-23-2021, 10:39 AM
zman1969's Avatar
I have another set of disc brackets available $50 shipped
ID:	568707   Click image for larger version
Old 02-20-2024, 09:06 PM
joes455 joes455 is offline
Any extra caliper lever E brake return springs?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 02-22-2024, 11:30 AM
zman1969's Avatar
Joe I got nothing but may ask out if someone could give spring dia and length you should be able to get something workable at True Value hardware
