Old 08-26-2012, 10:17 AM
lilredgto's Avatar
lilredgto lilredgto is offline
Default Honeycomb wheels
Just purchased 4 honeycombs and they need to be redone to be show quality. Wondering if anyone has tried powder coating or would the heat damage the polycast? Appreciate any thoughts.
Thanks.
Old 08-26-2012, 10:26 AM
The Boss's Avatar
The Boss The Boss is offline
I wouldn't try it. Powder coating requires temperatures in excess of 400 degrees, sometimes as high as 700 - I don't think the polly would make it, and if it did I would be concerned that it was still attached to the steel.
Do a search in the 70-72 A body or the 70-73 F body tech sections - there are plenty of threads on how to restore these wheels.
And go racin' in the street.
Old 08-26-2012, 11:31 AM
lilredgto's Avatar
Business that does the powder coating in my area stated 400 deg temp which is pretty toasty. I was wondering if anyone had done it with success, I guess paint might be the way to go! Thanks Boss
Old 08-29-2012, 02:21 PM
78w72 78w72 is offline
another thing to consider is that powder coating requires an electrical charge that attracts the powder to the part.... honeycombs are basically rubber on the inserts. i bet the powder wouldn't stickvery well if at all.
Old 09-01-2012, 06:22 AM
android 211 android 211 is offline
You can sandblast them and then paint them. The blasting will get all the old paint off but bounce off the polycast/urethane. I did it. Use appropriate paint for the urethane.
Old 09-01-2012, 01:29 PM
LeighP's Avatar
LeighP LeighP is offline
You can buy the correct Honeycomb paint in spray cans...it has a grainy, "cast" like surface to it that isn't like most normal auto paint.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
