Old 10-26-2012, 10:49 PM
Blk 76 Blk 76 is offline
Default Putting electric water heater in cabinet?
I had a small water heater that came in a metal cabinet that matched the height of the washer and dryer it sat next to and I had to replace it with one that does not have the cabinet and I want to know if I can enclose it with a cabinet made from wood? It does say this is suitable for under cabinets and it would have 4-6 inches clearance around it and on top. Being electric would it need ventilation?
Old 10-26-2012, 11:00 PM
sleepy's Avatar
sleepy sleepy is offline
Electric doesn't need ventilation, The tank is insulated so you don't have to worry about heat lighting the wood on fire or drying it out.
Why is he not suspended?
Old 10-27-2012, 08:56 AM
Cammer-6 Cammer-6 is offline
make sure you put a drip pan in and plumb the drain properly
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 10-27-2012, 12:52 PM
sonjaab's Avatar
sonjaab sonjaab is offline
U should be ok. I have just done a similar thing with a house I just bought.
I wanted the closet (under the stairs to the second floor) that had a direct
vent lp gas unit made into a 1/2 BATH as the pvc sewer pipes were directly
under that spot and a toilet waste line could be easily installed.
I put a new elec. shorty 28 gal. water heater in a dead space corner in
the kitchen hidden under the counter with easy access by removing the dish
washer and next to exposed existing water pipes and a spare 240 line.
Got tired of "sarge" beefin' about having to go upstairs to visit the potty!
This was a easy DIY fix to silence her !
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala,
94 Buick, 77 Triumph Bonneville
