| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
I want to spray about 400 ft. of OSB interior wall with white latex. Also the same amount of sheetrock. Neither has been primed.
This is work space, so I just want to brighten it up. Is there a commercial/contractor grade paint that will give one coat coverage, or will I have to prime first? I plan to rent a sprayer, advise on that is also welcome. |
You painting the smooth side of osb or the rough? Seems like rough would really soak up the paint.
I would prime first if it was me, expecially the drywall. Spray and backroll both coats.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Don't buy the cheapest stuff you can find. Use a good quality primer-sealer & paint. Backrolling, especially the primer, will give you better adhesion. Also, the higher the gloss of the paint, the easier it is to clean.
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt. |
Back rolling will also give you more uniform apperance.
The best way esp. to "seal" OSB in a work enviroment is to spray and
backroll it with oil based bin/kilz or enamel undercoater. Then a top coat of ordinary latex semi-gloss interior paint. Backrolling fills the voids and valleys in the OSB and makes the finish uniform. You could just cheap out and spray and backroll with any interior latex paint. I just did this to my new garage. I wired it, insulated, OSB on the bottom 4 ft. up and sheetrocked the remaining 4 ft. to the ceiling. Bin-ed the OSB and Painted it all gloss white latex. Sure is shiny and bright with all the new Fluorescent shop lites! Gonna be a SWEEEET place to do the resto on my 72 t-41 ragtop! MUCH better than my old cold, dark, drafty barn !!!!!!!!!!! Compressor, TUNES, press, grinder, benches, cabinets, vice, heat, exaust fan in place and ready to go!
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala, 94 Buick, 77 Triumph Bonneville Last edited by sonjaab; 11-01-2012 at 10:31 PM. |
![]() Lol! At your convenience, of course - but I'd like to see some pics from 400 4 spd and sonjaab if you could share. My shop is not finished inside and so I'm looking for ideas. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Fence paint.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
I've used white masonite board before and it is easy to wipe down. 1/8" sheets are 15 bucks a piece. While 1/4 is around $ 25. OSB is roughly 12 bucks a sheet and you have to paint it.
7/16 osb around 8 bucks last time I bought it. I'm doing the same thing-well I ahve the paint-need to take time. I placed the smoothest side out which has the labeling. I went to Sherwin-Williams (we have been dealing with them since the early 60's). I'm using white gloss latex. I will seal first with Kiltz or equiv. to seal labeling. Same thing to make the space look clean and large. I'm rolling evrything no spray. Bob
I just went to lowes and bought 2 5's of cheap contractor grade white for the osb in my 20 -24 addition with 12' ceilings, rolled it, good and bright
I will post some, but this is not a home shop. When I said "400 feet", I meant linear feet. (Actually it will be closer to 500.) It's 10,000 square feet of concrete floor with 8' OSB walls with sheetrock above some of that. |
This is unpainted and cluttered....................
first one is the 72 waitin' for resto, second one is the front wall and its OSB top to bottom and exaust fan installed (thats the box stickin' out on the right side of pic, it has doors on it, The third one is the side wall with bench, cabinet and tool box Fourth pic is lookin' to the double doors The clutter junk is now in the barn! Note: pics were taken with no flash just with the shop lights on!
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala, 94 Buick, 77 Triumph Bonneville Last edited by sonjaab; 11-04-2012 at 01:36 AM. |
I did my whole garage with OSB, primed and painted. I used Duron High Gloss Exterior paint. Had to wipe grease off a few times from friends putting greasy hands on the walls and it came right off. Nice and bright as well. I painted the bottom 2 feet black so it wouldnt show the dirt from sweeping, mopping or feet hitting it.
Thanks for the pics and ideas, guys.
I did OSB (unpainted) at the old place - ![]() ![]() but I think I want to do something different, and a bit brighter, for the new shop: ![]() ![]() ![]()
