Old 11-04-2012, 03:50 PM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
Question 68 Factory Dip Stick Question
Greetings, did the factory dip stick for the 68 TH400 have a holder welded to it to hold wires? I'm trying to see if the one in my spare parts fit my 68 FB. It has the mount for the bolt. It also has a piece with plastic, or rubber, inserts that looks like it held wires. Thanks for any information. Good day friends. Mike
Build it fast, build it right, hold On TIGHT !!!
Old 11-05-2012, 07:51 PM
frankyboy455 frankyboy455 is offline
The dipstick has a welded tab on the tube that bolts to the back of the motor, using same bolt that bolts the transmission to the motor. There is a separate tube for the starter wires.
Old 11-06-2012, 01:24 PM
RR67GTO's Avatar
Thank you. I Will try to post a photograph and see if I have the correct one. It's been so long since the tube was in the car. I also have dip stick tubes from other cars and trucks around this place. Thanks again friend. Mike in Oregon
Old 11-06-2012, 07:19 PM
the 67-69 TH400 dipstick is very scarce and odd looking. Lots of curves.
Old 11-07-2012, 12:00 AM
RR67GTO's Avatar
Greetings, I didn't get a chance to photograph the dip stick and tube today. I'm trying to get at the bolts on the PS pump on my GTO. However, I will try in the next day or so, and would appreciate it if someone can recognize if it's 68 Firebird or not. Thanks again friends, and my best wishes to you all. Mike
Old 11-09-2012, 01:01 PM
RR67GTO's Avatar
Question Are these 68 FB TH400 Dip stick & Tube ?
Good morning friends. Her are two photographs of the Transmission dip stick and tune. Are these from my 68 Firebird with the TH400? Thanks for any help. Mike in Oregon
Name:	DipStick CLOSE.jpg
ID:	302685   Click image for larger version
Name:	Dip Stick 1.jpg
Old 11-09-2012, 06:18 PM
no Mike, that is not it. i'll try to send a picture this week-end. Frank.
Old 11-09-2012, 07:19 PM
RR67GTO's Avatar
Frank, thanks for the response. I have had other Pontiac's as well. SO it has to be from one of them. Maybe a 66 Le Mans with a 326? I do know I have a lot of 68 FB parts, down to most of the 68 front Disc brake parts. Again, thanks frank. And the pix would be a great help. Mike in Oregon
Old 11-09-2012, 09:24 PM
Hey Mike, here's a pic of a 1967 Firebird 400 Th400 dipstick. I can assure you 68 and 69 are the same, I have them all here at home.
Old 11-09-2012, 10:22 PM
RR67GTO's Avatar
Frank, thank you very much for posting the photograph. That's great, because I have the tube and stick that's correct for a 68 bird. Unlike the one I posted, the 68 is in warm, dry area of my shop. Thanks again. Mike
