Old 12-03-2012, 08:03 AM
RamAir's Avatar
RamAir RamAir is offline
Default Engine Vin Stamp
The Vin Stamp has a misstamp at the end. Was this common? 70 Norwood Trans AM
Old 12-03-2012, 08:15 AM
LeighP's Avatar
LeighP LeighP is offline
Yes, mis stamps are fairly common. my 77 T/A had a ghost stamp on the engine number itself where the stamper must have double tapped, and it bounced.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 12-03-2012, 08:47 AM
Does that stamp have 29N at the front?
Old 12-03-2012, 09:06 AM
RamAir's Avatar
Yes, it begins with "29N"
Old 12-03-2012, 11:06 AM
This isn't the original engine for the 70 TA then?
Old 12-03-2012, 11:41 AM
RamAir's Avatar
I believe it is. Block Casting # 9799914, prefex WS 0585920
Old 12-03-2012, 12:30 PM
If there were inconsistencies with the engine/stampings - would you rather know them
- or would you rather Not Know Them ?
Sometimes its a delicate situation for an owner.
Just need to confirm your wishes before more is discussed probably.
Old 12-03-2012, 12:46 PM
RamAir's Avatar
Nope, I'm definitely interested to verify the originality. I am not questioning anyone's authority, just trying to get it straight.
Old 12-03-2012, 01:14 PM
Just wanted to know how you felt about some "possible" bad news first.
29N
the 2 is a Pontiac designator
the 9 indicates it was an engine for a 1969 production car (you have a 70)
the N indicates Norwwod plant
When a double strike happens on an engine VIN at faktry -
basically the whole group is restruck.
They use a gang stamp holder fixture - not each number stamped individual.
All characters should be in a perfect strait line with each other on each "strike".
And all should share the same font and size.
Restrikes can take on many appearances - heavier or lighter to one end than the other - a bit misaligned from original strike - etc...
i had some sample pics but cant locate them.
The next issue is that a WS would not have been instituted at Norwood in 69
Best things to do:
Wipe your engine VIN area cleaner with lacquer thinner - or sand it cleaner with 180 grit sandpaper and take more pics.
Get the date code from around distributor mounting hole. (B149 for example)
Clean or sand your WS stamp and take some pics.
Then post the pics /findings.
Old 12-03-2012, 02:18 PM
RamAir's Avatar
29N
Best things to do:
http://s1115.photobucket.com/albums/...rotter54/70TA/
Old 12-03-2012, 04:49 PM
RATTCRUSHER455 RATTCRUSHER455 is offline
Default RAM AIR III BLOCK
THE S ON THE WS LOOKS A LITTLE WEAK
Old 12-03-2012, 04:53 PM
I WOULD BET MONEY THAT BLOCK IS A RESTAMP
Old 12-03-2012, 05:43 PM
Is the 122912 the last 6 numbers of the car's VIN?
Old 12-03-2012, 05:52 PM
jmt455's Avatar
jmt455 jmt455 is offline
400guy: If you've got the PHS documents for this car, you can also verify the engine unit number on the car "Billing History" form.
It should match 0585920 (or at least the last 4 digits of that number)
It might show: WS5920
Old 12-03-2012, 05:54 PM
Looking through my EUN page, it appears the EUN is within range of the engine and the date code.
I'm wondering if the stamper didn't screw up the '9' along with the other digits?
Does it look like a '2' under the top '2'?
(looks like it may be something else)
The area around the stamped VIN looks original and not ground on.
Cool engine.
Old 12-03-2012, 06:04 PM
2manyT/A'S's Avatar
Just to sum this up........(if I'm reading the codes right?)
We have a 1970 400? block cast on May 19/70 in a 70 T/A vin (228870N122912) that was built in the first week of June 1970 with a block code stamp WS & partial vin of 29N122912?
Is your car a survivor,restored OR basket case?
Is displacement (400) cast above pan rail behind fuel pump?
Has block cast # below rear of PS cyl.head been tampered with or modified?
Eye Candy......garage band?
Go full screen & turn it UP!
Old 12-03-2012, 06:08 PM
RamAir's Avatar
affirmative
Old 12-03-2012, 06:09 PM
RamAir's Avatar
I have the PHS invoice, but I do not see a "billing History" form
Old 12-03-2012, 06:11 PM
RamAir's Avatar
We have a 1970 400? block cast on May 19/70 in a 70 T/A vin (228870N122912) that was built in the first week of June 1970 with a block code stamp WS & partial vin of 29122912?
partial stamp is 29N122912
Old 12-03-2012, 06:13 PM
The Boss's Avatar
The Boss The Boss is offline
EUN won't be on any form from PHS on any car after 1968 unless you have GM of Canada documentation.
And go racin' in the street.
