Old 01-01-2013, 12:20 PM
johnmilza's Avatar
johnmilza johnmilza is offline
Default Bracket color
I am repainting the accessory brackets on my 72. What type of black? Satin, semi gloss or full gloss
1972 GTO Hardtop - 400, M22, Cardinal Red now Nocturne Blue
Treasurer 2008 GTOAA International Meet
Old 01-01-2013, 11:25 PM
GStage1's Avatar
GStage1 GStage1 is offline
All GM A-bodies I have seen, use satin black for brackets.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 01-02-2013, 12:15 AM
PB's Avatar
PB PB is offline
All original alt. brackets I've seen we're not painted, they are natural metal.
Pat Brown
Old 01-02-2013, 10:20 AM
johnmilza's Avatar
Pat
I am looking for the shade of black for Alt bracket that mounts to the block and the power steering brackets. these are steel. if they were natural they would've rusted. mine were definitely painted some shade of black.
John
Old 01-02-2013, 05:59 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
Isn't it a 60 degree gloss? I believe it's the "Underhood" black our sponsor sells.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 01-02-2013, 06:47 PM
johnmilza's Avatar
Performance years site says it is now supplied by Eastwood. Is eastwoods underwood black close to original finish?
Old 01-02-2013, 10:26 PM
A.W.Dille A.W.Dille is offline
I don't know about the Eastwood but I have went to using The Underhood Black from NAPA. May not be correct but I feel it's close. Some others may have used other paints that may work better.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 01-07-2013, 10:12 PM
johnmilza's Avatar
Just cleaned up the ring that bolts lower pulley to balancer. All the oil preserved the paint underneath? Very close match to Eastwoods underwood black.
Old 01-08-2013, 11:03 PM
Originally Posted by johnmilza View Post
Pat
John
Original alt & ps brackets for '71's, '72's. 73's were not painted. Originally they had a black phosphate finish which disappears after many years. The brackets & small idler pulley used with the optional 80 Amp idler pulley set-up also received a phosphate finish that faded with time.
71+ w/p & crank pulleys & the retaining ring for the crank pulleys were originally dip painted near 90% gloss. NOS examples of '71+ engine pulleys will often be near 100% gloss black. In estimating 90% gloss am going from experience refinishing these pulleys, & was confirmed again in '98 when I dragged in a garaged all its life 4K mile original '72 Lux LeMans as a parts car. So many times home restorers break out a can of 1613 Krylon or other satin black spray can & paint all the '71+ brackets & pulleys that color, it will look better than nothing, but is not correct.
Old 01-09-2013, 12:19 AM
PB's Avatar
PB PB is offline
Ahhhh... Thanks Roger, now that makes sense of all my brackets I've gathered over the years. My HO was missing that rear alt bracket and all 3 of the ones I had we're all natural metal. Faded. Led me to believe they were not painted. My original HO AC bracket looks the same way.
Pat Brown
Old 01-09-2013, 11:35 AM
johnmilza's Avatar
looking at what i have been blasting cinfirms that. the pullys and ring clearly showed that they were dipped. my alt and P/S brackets had been rattle canned at one time black.
Is there a way to duplicate the original black phosphate finish?
Pat - do you have more pics of that engine you can send me - I would love to have them for reference
Old 01-09-2013, 12:51 PM
Bentwheelbob's Avatar
Default Black Phosphate
Check out Palmetto Enterprises or Brownells. They both sell DIY phosphating solution that is easy to use and effective. Skip the Eastwood stuff. I'm sure if you search this forum you can find some photos and discussions. Also, there are a ton of youtube videos on doing a black phosphate finish as this is the common milspec gun finish.
Old 01-09-2013, 03:19 PM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
Lines up with what I have noticed while judging a few documented 72 survivor cars. The finish on the brackets after all these years looked light a light grey phosphate. It was obviously darker when new.
P.O.S.I - It's not just a club...it's an addiction!
Old 01-09-2013, 04:59 PM
PB's Avatar
PB PB is offline
There are a bunch on my web site. I've been documenting my engine and all the original parts. If you need a specific shot, Lmk.
Pat Brown
Old 01-10-2013, 04:29 AM
Loffen's Avatar
Loffen Loffen is offline
My Palmetto black -71 brackets, they are darker in real life.
And mounted on the engine
