| The Body Shop TECH General questions that don't fit in any other forum |
Body still in primer and vinyl top has been stripped off on 71 GTO. Will install new top when car gets finished but in the meantime I would like to re-install front windshield and also the rear window. Would it actually be better to have the top installed first before installing glass or or does it matter.
I would put full paint under top and window openings
Yes it is better to do top first as its real hard to cut around the studs with glass in and you risk cracking glass too.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. ![]() |
x3. You'll get a better top installation w/o the glass installed.
X4 on everything above!!! And if you plan on installing a new headliner, do it while the glass is out also. It makes it a little easier to stretch and pull.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
i'd be most concerned with painting the window jambs with a 2 component topcoat (catalyzed) so that you don't eventually get moisture under there and subsequently rust. irgoatmike
