Old 01-10-2013, 03:13 PM
PB's Avatar
PB PB is offline
Default Fill holes with epoxy/jb weld?
Would it be alright to fill theses small holes with a jb weld,, then follow up with Master Series silver, epoxy primer?
Can I get away with the above process without cutting and welding in new metal?
I have a couple holes that are a bit larger on the top side of the window channel. Can I do the same on the larger holes?
I've wire wheeled the window channel, now my plan is to fill with jb weld, master series, epoxy prime.
Pat Brown
Old 01-10-2013, 03:16 PM
PB's Avatar
PB PB is offline
Another shot.
Pat Brown
Old 01-10-2013, 03:59 PM
steve v's Avatar
steve v steve v is offline
JB may be a little on the runny side to use on the holes unless you can get on the backside w/some tape to keep it from oozing thru. I've used the POR 15 two part epoxy putty kit on similar sized holes in floor/trunk pans before with ok results.
How long the repair will last is anyone's guess.
Old 01-10-2013, 04:46 PM
Rob B's Avatar
Rob B Rob B is offline
Originally Posted by steve v View Post
J
X2.
I went thru the same issue on the wifes car and just bit the bullet and welded in new metal. When I was all done, I was glad I did. One less thing to worry about.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 01-10-2013, 05:01 PM
Bob Scott Bob Scott is offline
Welding in new metal is the best way to go but if you don't want to do that maybe metal to metal filler would work
Old 01-10-2013, 07:28 PM
JUDGE3 JUDGE3 is offline
I have used a quality body filler twice in this area with excellent results. although mine were pitted but no full through holes. none the less, small holes no big deal.
The thing is, you have to get 100% of the rust off the pits. then I treated it further with rust neutralizer, then its no different than filling a dent in a panel. I sandblasted. only way to get it all.
myself I don't see any reason for Jb weld even if it were thicker.
Old 01-10-2013, 07:38 PM
400 4spd.'s Avatar
If you have a hole, rust is now on the backside.
Old 01-10-2013, 08:37 PM
carcrazy carcrazy is offline
Obviously replacement of the metal is the best way to go. For a short-term repair filling will work but I'll bet that you'll be revisiting the problem a few years down the road!!
Old 01-11-2013, 06:15 PM
gary bennett's Avatar
gary bennett gary bennett is offline
i would use ( ALL METAL ) i mixes like bondo
DBANDGB
Old 01-11-2013, 07:18 PM
nytrainer's Avatar
nytrainer nytrainer is online now
My 2 cents, if you aren't going to replace the metal I would put down epoxy primer FIRST(after spot blast, etc. to get as much rust as possible) BEFORE any filler whether you use Metal to Metal, Rage etc.. is your choice. Garage, nice weather use car should last a long, long time.
Old 01-12-2013, 12:30 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
If your going to keep the car then weld in new metal. To go the cheap route if selling the car I would use fiberglass resin to plug the holes and have something to support the JB weld.
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 01-12-2013, 12:56 PM
ANDYA ANDYA is offline
If your not going to weld in new metal I would try and at least blast the area. Then I would treat the area with phosphoric acid to get rid of any remaining rust. Soak the area good and keep it wet for along time. Work the area with a wire brush and wipe of the acid with paper towels. Repeat this process several times until your sure the rust is gone. Then I would fill the area with All Metal and sand before you apply a final coat of filler.
Old 01-12-2013, 03:44 PM
X2 Works excellent. and in this area would take an awful long time to have any spots return when done as above.
Old 01-12-2013, 06:06 PM
PB's Avatar
PB PB is offline
Thanks for all the advice....just bought the master series silver. I plan on keeping the car, so I don't know which route ill take. Need to buy a welder. I know removal is best way to go, but a lot of what I'm reading on here about the master series, I don't think it necessarily has to be cut out. I'm going to pull the dash and get a good look from underneath.
Pat Brown
Old 01-12-2013, 06:31 PM
If your pulling the dash, the access will allow you to por15 the bottom.
I used por15 on the back side of everything I accessed.
Old 01-12-2013, 06:44 PM
Josh.AZ.GTO's Avatar
Josh.AZ.GTO Josh.AZ.GTO is offline
I just got a new POR15 catalog and they have this stuff called POR patch. It seems to be designed for the application your referencing. Although you would want to do both top and bottom for best results.
