1963 Lemans Cage
I figured I was far enough along to post up some pics of my cage going in my 63. I have to finish weld everything this weekend and then start on the tunnel and floor. This is the first time installing a cage in a car for me and it's quite the "learning" experience. I kept the rear frame rails, basically went from the ladder bar x-member forward. Someday I might backhalf it, but I already have a big tire car. I want to stay with a 9" or 10" rear tire for this car. I bought a pre-bent 14 pt. cage from http://autoweldchassis.com/index2.ivnu and it fit pretty damn good. Paid an extra $20 to have them fishmouth most of the tubes and it made things alot easier.
I'll post more pics as I move along. Hopefully I'll have the floor done in the next few weeks.
________________________________ Paul Tavana Tribute Car https://www.hotrod.com/articles/hppp...tting-it-done/ 10.40@126 mph all motor |
More pics of the cage...
That is a nice looking fitting cage, Looking sweet.
GT. |
Looks good, how does it fit against the roof?
Thanks Stan |
Based on the two C's on the quarter I have to say it's the "Bad Obsession" Lemans???
Is that mild steel or chrome moly?
One thing about the 63's is they will except a big tire without any mods to the whell wells. R70 Judge put a 12:50 tire in his. It's tight but it looks Bad Ass. Keep it up, looking great. GT. |
[QUOTE=xitmnt2;4831533]Transporter, the fitment of the main hoop is spot on. You can basically fit your finger around the bend between the bar, the roof, and the pillar. The main hoop is shipped long, so you have to cut about 3 inches off each end depending on how tight you want it to fit. See photo below, just dont make fun of my welds, its my first time with a tig. Awesome work on your project, im following your build also.
Thanks same on yours, but am starting to think that soon the drag strips and streets of America will be over run with early Tempests, lol Main reason I asked about the cage was IF I decide to do one, I was thinking of putting it "into" the dash and trying to hid the uprights right next to the A pillar and the main hoop right at the B. Do they give you enough tube to move the A pillar bar forward 6 to 8 inches? Thanks Stan |
Stan,
No, there isn't enough on the A-pillar bars to move them that far forward. The door bars would be too short also. They do fit tight to the dash and the pillar, and there is ample room to move your legs/head around them. Im putting in a swing out bar, so that should make it easier too.
Yeah, real reason I want to put the bars into the dash is because I want to bring front strut braces back off the front frame horns into the firewall and tie into the A pillar bars. I would like ALL of that to be behind the dash and out of site, besides I still don't know, but I might want to mount hanging pedals with reservoir off the under dash cross tube so that the firewall is "clean". Thanks for the input. Stan |
It's tight, but it does fit. I haven't "adjusted" the stock wheel wells at all. A few whacks with a big F hammer would easily free up some more breathing room. Cage is looking great
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
http://www.cachassisworks.com/c-165-...evis-sets.aspx
R70,
I think I had asked you last yr. about your front motor plate and how it fit. I know you responded, but I cant find the post. You used the AP plate if my memory is right, but which one? I see they have 3 different ones. If you have any pics of the plate fitment could you post them if you get a chance? Thanks a ton.
________________________________ Paul Tavana Tribute Car https://www.hotrod.com/articles/hppp...tting-it-done/ 10.40@126 mph all motor Last edited by xitmnt2; 01-20-2013 at 10:41 AM. Reason: mis-spell |
AllPontiac AP-FMP100 http://www.allpontiac.com/steelfrontmotor.html I snapped a few pics for you during halftime
R70,
Awesome... thx for the pics!!! Much appreciated. Got done finish welding the cage this afternoon, ordering paint for it tonite. Now if I can figure out how to tin up the floor and transmission tunnel... I'll be set.
