Old 01-19-2013, 11:34 AM
pontiacmonstr pontiacmonstr is offline
Question is this a factory cc set up?
i went to pick up a pair of doors last week and the kid had a 78 t/a there that he was working on. i looked it over and noticed the cruise control set up. i haven't seen a set up like this before. factory?
ID:	310218   Click image for larger version
ID:	310219   Click image for larger version
ID:	310221   Click image for larger version
ID:	310222   Click image for larger version
Old 01-19-2013, 11:53 AM
Factory Pontiac F-body set-up. Thought that version with the remote vac actuator ended after '77 models, but as you have posted, was still offered in '78. Have several such set-ups. '79, the vac actuator was bolted a rod set-up on the intake, similar deal on '80's & 81's.
Old 01-21-2013, 11:42 PM
74Grandville 74Grandville is offline
when i picked up my 1979 firebird, (43,000 miles), it had a working setup with the 301. pretty cool in my opinion with no computer.
Old 01-22-2013, 12:33 AM
Grand73Am Grand73Am is offline
Yes, I've also seen that cruise vacuum actuator on the firewall like that on 77-78 Pontiac 400 firebirds/TA's. I don't know about earlier ones. The Olds 403's have it on the intake.
I've heard that the 4 speed cars weren't offered with cruise, but don't know how true it is. If is it true, then there was no cruise on 79 TA with 400's, since all of them were 4 speeds.
Steve F.
Old 01-23-2013, 07:07 PM
burd's Avatar
burd burd is offline
Looks like my 78 but it looks like your missing some stuff.
Old 02-05-2013, 10:11 AM
rockin78T/A's Avatar
rockin78T/A rockin78T/A is offline
Looks right to me for a 78, I'm glad you posted these pictures. I took all this out of my T/A several years ago, now I kinda have an idea where all those parts go back too.
God didn't give you a belly just to hang a button on it!
Old 02-05-2013, 09:08 PM
2manyT/A'S's Avatar
NO cruise control on ANY Man/trans Firebird until 1982,as I recall.....
Eye Candy......garage band?
Go full screen & turn it UP!
Old 02-05-2013, 10:04 PM
FrankieT/A's Avatar
That set up is correct as mentioned in all posts. True no cruise on manuals. However, I just installed cruise on my 4spd car because I travel a lot with my car. It works perfectly. I was concerned about serging with the direct connection(no cushioning effect from converter). But no issues but obviously no safety on clutch. Acually, the servo cable doesn't have enough stroke to floor the car sort of speak, if you depress the clutch while cruise is on it will only go to about 3000 RPM. My idea was to get the cruise up and running and then install a kill switch on the clutch pedal, but I'm really the only one who drives the car so I'm too concerned. I used all factory parts, except I didn't use that servo on the fire wall cause it really got congested the area between the evap case and hood scoop. So, I pirated a servo with a long cable and mounted it on the wheel well behind the battery. It's not visible and the cable runs inside the fender, around the booster and to throttle.
