Rust free 69 Bird rolling
Rust free 69 Bird rolling. The one in my SIG pic. $6000
69 'Blackbird' 535 CID IA II SD Wide Port E-head Pro Systems Dominator |
more info and pics?
What would you like to know? PM me.
x2! rear specs, front end, whats in the interior, any water damage. Thanks Dave
OK here goes, NO WATER DAMAGE OF ANY DESCRIPTION!!!
Front end:stock control arms, Moroso trick springs, 90/10 shocks. Wilwood featherlight disc setup that worked great. Front runners on Weld rims Interior: 2 Racing buckets, no gauges in dash, big tach. 10 pt Moly cage (with outriggers to the front frame rails) done by a pro (Farks Supercars in Brooklyn) for almost 5k in '09. All 4 new floor pans welded in at that same time. Professional tin work between the tubs. Rear end: Back half (square tube) and tubbed 9" with disc brakes. Brand new (fall 09') Strange center section with 5 passes on it. Brand new at same time Strange 35 spline axles. Spool with 3.89 gears - no passes. Installed after I decided 4.30 was too much gear. Adjustable coilovers. Weld wheels with 31x13 slicks (also 5 passes). Long studs. Sheet metal fabricated full trunk pan. 15 gallon cell, battery box. You can even have the ugly purple wheelie bars. It was never a pretty car but it was well capable of going very fast, SAFELY. Was 3225lbs with me (225lb), a 535, and a t-350 in it so it is light. Anybody with genuine interest, PM me your email addy and I'll send you pics of whatever you want. When I get home from work, I'll post some pics here as well. All in all this was a well done car that never even scratched the surface of what it was capable of. It launched hard and went arrow straight. It's a shame that I only got the opportunity to make 5 passes. The hood is a Glasstek bolt on 5" cowl, the decklid is a glass pin on. Aside from those, all factory sheet metal and glass. No rot. Drive shaft loop also.
Thanks for the response, Im in no hurry Ill wait for pics to be posted on the thread
Electrics in place? Just drop a mtr & trans in and go? Thanks Dave
Here are some pics as requested
More pics...
If anyone wants a pic of something specific, let me know. Also, this car has an intact VIN and can be registered and put back on the street if you want. It has no wiring/lights in it at present but I do have the harness for the rear purchased from PY that go with the car. Pic one was before the new coilovers were installed, pic two of the Wilwoods, pic three shows the new pans. Note: the shifter, 2 step, and retard box have been removed
Fair Price!!!! Should sell quick....Did ya build a new toy? Here is a pic of my project...Hope to be racing soon if I dont go broke!!! Good Luck Russell
Thanks bro. I hope it does. No new toy, I'm out of the drag racing biz for a minute. I'm looking to make a deal.
Your bird looks badazz bro. Best of luck to you.
bump
bump for a great car, Ive got a similarly built car and wouldnt sell it for double this price!!
If I didnt already have one Id jump on this myslef. Great price!!
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
