Old 01-25-2013, 10:27 AM
PonchoV8 PonchoV8 is offline
Default Galvanized sheet metal for plenum?
I need to replace a piece of HVAC return air duct. It's just a simple box and the HD and Lowes stuff is thin junk. Recommendations? Been waiting on a friend to get this for me, but that's just been a waste of time.
Old 01-25-2013, 11:03 AM
Cammer-6 Cammer-6 is offline
try a/c-heat contractor
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-25-2013, 11:07 AM
Have never had to replace a return. Have rebuilt several supply boxes in the slab. Might try this manufacturer, most likely, they may supply heat & a/c contractors in your area
www.royalmetalproducts.com
http://www.royalmetalproducts.com/images/catalog.pdf
Old 01-25-2013, 04:18 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Greymetalsouth might be product in your area too.
Try a local HVAC supplier parking lot. It takes a good guy just a few to bend it right up if you have the measurements and male & female ends determined. Most of them I know are fun to hang out with on Friday afternoons. My neighbor has a massive break that I use to make sheetmetal projects with. I have to get it done before the jug comes out though or I forget what I went over there for.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 01-25-2013, 04:35 PM
Forget the sheet metal. Where's that jug?
Old 01-25-2013, 05:59 PM
sdx455's Avatar
sdx455 sdx455 is offline
get one of those sheets of fiberglass duct board and some silver tape .
73 GTO 455 TKO 600 3.90
Old 01-25-2013, 06:10 PM
The location is at floor level right in a higher traffic path where durability is important. Kicking and hand-trucking past is an absolute.
Old 01-25-2013, 07:53 PM
Deadhead's Avatar
Put some bead board on it with molding around it. Plexi over it if necessary.
-LBJ
66 Bonneville wagon
2005 GMC L-33
Old 01-25-2013, 08:11 PM
sheet metal is required on discharge side of heat strips
Old 01-26-2013, 02:50 PM
Thanks all.
