| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Have a 261HD transfer case for the above truck that let go. It had the dreaded oil pump moving around problem that wears a hole in the transfer case. About a year and a half ago, it developed a small hole and blew all the ATF out the case. JB welded the case back together and added fluid. Worked fine till last week when pushing snow, it died. Took it out of the truck and split the case. Am trying to get the oil pump and shaft half out of the case, but it won't slide. The breakdown looks like their is a clip behind the oil pump, but you can't get to it till you get the shaft slid out. I can't het the shaft slid out. Any tricks to this??
Again, this is the 261HD transfer case, which has the manual engagement in the cab, not electronic. Any help appreciated. Thanks, JOHM
74 GTO 406 T400 74 Firebird 350 4-speed 68 GTO Convertible 400 T400 76 GP LJ 400 4BBL T400 78 Chevy 1/2 Ton Truck Oh yea I love my wife very much For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm |
Found the acces hole for the clip. No brainer really, just was'nt paying attention
Ah............The dreaded "pump rub" issue !
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala, 94 Buick, 77 Triumph Bonneville |
Did you buy the kit that fixes the prob? I had the same prob on my son's Tahoe. Put in the kit for $70.00. Permanent fix!
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
This effects all late model New Process GM cases in both the 1/2 and 3/4 tons.
The dreaded issue and the Merchant Auto "fix kit cure" link http://www.merchant-automotive.com/t...grade-kit.aspx
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala, 94 Buick, 77 Triumph Bonneville Last edited by sonjaab; 01-31-2013 at 11:55 PM. |
