Old 02-03-2013, 12:41 AM
ironman ironman is offline
Default Offset grind crank
Wanting to offset grind my factory 455 crank to BBC size to increase stroke to 4.25. Not normally a problem but the crank has a fresh unused .010" grind on it. This would leave one side of the journal untouched, not ideal in any world. My question is can I have the journal machined to BBC minus .010" without causing any issues or problems with availability of bearings. I know the purchase of a new crank already at this stroke is probably the thing to do but living in Oz the cost of freight scares me somewhat and I already have a perfectly good crank that I would like to use, any thoughts would be appreciated.
Old 02-03-2013, 01:26 AM
Tim Corcoran's Avatar
You should have no problem stroking it .040 and using a .020 oversize BBC bearing. You should have no problem getting .020 over bearings. Just make sure you have a good crank grinder he puts a nice radius on the journal.
Tim Corcoran
Old 02-04-2013, 01:55 AM
GRX's Avatar
GRX GRX is offline
x2 on ensuring a proper radius. When removing excessive amounts the machinist may need to re-dress the stone radius more than usual. Some guys may charge extra for that. Some not.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 02-04-2013, 09:07 AM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
I just remembered I have one of those. They were used before the influx of aftermarket cranks. I personally can't see the sense in doing one these days, unless shipping is serious $$$. The one I have was only able to be offset ground to 2.240.
Old 02-04-2013, 12:21 PM
X 3 on the radius! Are you SURE your crank is "on stroke" now? Have you measured it?
Dr. Thomas Sowell
Old 02-04-2013, 01:13 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Seems like alot of extra expense since you have a fresh crank already and have the rods and pistons for the 4.21 stroke? ...i would leave it alone, unless you already have the bbc rods and right comp. height pistons.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 02-04-2013, 09:22 PM
BVR421's Avatar
BVR421 BVR421 is offline
DITTO, I would live with the 4.21 stroke. I did my 482 with a factory cast offset back when the then popular Eagle -cast- 4.25 cranks were temporarily unavailable
they were stuck in the Long Beach dock strike for several months
whatever, that offset crank ended up costing me near what a new 4.25" -forged- crank can be had for now days.
Ive had fun with it but the stock 4.21 stroke would have done as well with less side load on my factory block.
