Old 02-07-2013, 02:35 PM
Default 68 GTO hood question
Back in the day (late 80's) I used to comb Pick-A-Part yards in CA and I found this hood in the yard and I've had it ever since. What's different about it are the holes right in front of the hood hinges. On every other one I've seen, the holes are rectangular, but on this hood they're round. These holes are put there to collapse the hood (make it buckle) in a head-on collision, but this is where they buckle over time just from being raised and lowered.
Does anyone know if it makes this hood an early 68 GTO? Is the round hole common?
Old 02-07-2013, 04:24 PM
What is the date code read?
I thought 68 hoods had the brace behind the scoops?
Old 02-07-2013, 10:11 PM
I didn't know they were dated. Where do I find the date code?
Old 02-07-2013, 10:16 PM
I do believe that the collapsible hoods were later...So, you may be right about it being an early hood.
Old 02-07-2013, 11:57 PM
Usually on the flat surface at the back drivers side corner of the hood behind the hinge
Old 02-08-2013, 05:58 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
That's a he!! of a hole the hacked in for the hood tach. Looks like it could be bent back and welded up tho. I just looked at my 68 and it has round holes.
TigerEFI.com (Classic Pontiac Fuel Injection)
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
Old 02-08-2013, 09:08 PM
I think they used a can opener to make that hole. Thanks for checking your hood. I suspect these hoods hold up much better than the rectangular holes.
Old 02-09-2013, 10:48 AM
marshallbeach marshallbeach is offline
The way the underhood bracing look's in the fan shroud area, it's a 1968 hood.
Old 02-09-2013, 10:55 AM
Sorry, I mistyped. 69 hood.
There is a photo of a hood I sold on the Detroit Craigslist I pulled off a 1970 RA GTO.
Old 02-09-2013, 01:01 PM
Marshallbeach, unless my eyes are going bad..I'm pretty sure that's a '68 hood.
I don't see the 'fan shroud dimple' of the '69/'70 hoods.
Found a good pic of the '69/'70 hood bracing dimple-
ID:	312621   Click image for larger version
Old 02-09-2013, 01:54 PM
Thanks Greg, you mean my typo was correct? I should not have proof read my post.
By the way, I have had the photo of your 66 as the backdrop on my desktop for a long time. Hope you don't mind.
Thanks again,
Jim
Old 02-09-2013, 05:10 PM
Thanks again,
Jim
MY '66?...lol....that's hard to believe. It's a yard ornament.
Maybe you mean the one in my avatar going down the assembly line?
Old 02-10-2013, 08:34 AM
Nope, the yard ornament. I discovered at an early age, the most pretty isn't always the most beautiful.
Jim
Old 02-10-2013, 11:04 AM
richmas5 richmas5 is offline
That's an early 68 hood,rectangular cutouts came later,also the front bracing is straight,not contoured like 69 70 to accomadate fan shroud on the 69 70
Old 02-10-2013, 11:06 AM
dmorg1's Avatar
dmorg1 dmorg1 is offline
Default code
thews,
Were you able to locate the date code?
north,
Concerning the code, is it correct that the letter is the month and digit or digits = the day of the month or is the code interpreted differently?
Both of these 68 hoods have the oblong cutouts
Dave
68 GTO
68 GTO Convertible
68 LeMans
68 LeMans Convertible
68 Tempest Convertible
79 Firebird
Old 02-10-2013, 12:09 PM
Thanks again,
Jim
Of course you are welcome to the photo. I'm in agreement. I'm kinda liking the patina on my '66 and may keep it that way whenever I get around to doing anything with it.
Old 02-11-2013, 04:39 AM
PaulatFast PaulatFast is offline
There are three dfferent 68 hoods. The one without the crumple slots is the earliest. I have not been able to pinpoint a changeover date for this... I have seen Oct hoods without them and Nov hoods with the holes...
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 08-18-2018, 07:14 PM
rare4k's Avatar
rare4k rare4k is offline
did the 68 hood style run on early 69 cars? I just bought a 68 hood that has the braces in the scoop area and has a 9 under the back side the side date is 12-B 5
Old 08-18-2018, 07:16 PM
rare4k's Avatar
Side date
Sent from my XT1254 using Tapatalk
Old 08-18-2018, 07:18 PM
rare4k's Avatar
Square crash hole
