Old 02-21-2013, 08:07 PM
buddy in texas buddy in texas is offline
Default Looking for A/C vacuum line grommet for 65 Tempest/Lemans/GTO
Can anyone tell me where to locate a replacement rubber grommet that passes through the blower motor case under the hood and has 4 holes for the vacuum lines and one hole for the electrical harness pass through. This is for a 1965 GTO, but I assume is the same as a Tempest/Lemans. Thanks in advance.
Old 02-22-2013, 07:36 AM
Jeff Hamlin's Avatar
I'm not sure it's the same Dia; but Ames shows one for use on the hideaway light cars.
It looks as it may be usable. I ended up securing a good one off a Donor car.
Old 02-22-2013, 08:07 AM
Old Goat 67's Avatar
Best I could find when looking, but did not try one. See here, http://forums.maxperformanceinc.com/...grommet&page=2, post 26 on.
http://www.parts123.com/parts123/yb....~Z5Z5Z50000050
Could you measure the hole size? Let us know if you do try one.
Charles
Old 02-22-2013, 01:08 PM
Thanks Jeff. I found it in my Ames catalog. It might work. Will have to do some measuring.
Old 02-22-2013, 01:11 PM
Charles
Thanks. I will let everyone know if I go this route. I may actually try to fabricate one myself out of rubber if all else fails.
Old 02-22-2013, 04:58 PM
chrisp chrisp is offline
I have these if they will work .
ID:	314012   Click image for larger version
ID:	314013   Click image for larger version
Old 02-22-2013, 05:31 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
On my 64, I was able to use this grommet for the fuel tank vent. It fits the hole perfect. 64 only has two hoses there, so I just had to drill them out larger. I'm sure you could drill more with patience.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, next project
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
