Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Fixing cracked poly/plastic.
I have two things that need cracks fixed. The first is an outdoor wheelbarrow/cart. The upper lip of the container is cracked. The second is on the interior of an SUV. It's the brace that contains the cargo cover and goes from side to side. It's not necessary for the operation of the cargo coer but it finishes out the trim. I used Super Glue and it does seem to adhere ery good.
Try plastic model glue.
Why is he not suspended? |
Testers. used to be good, I haven't put together a model for years and with all the "protect people from themselves laws" they may have had to changed the formula of the glue to keep idiots from sniffing it to get high. But you can get it anywhere they sell plastic car models. Model glue actually melts the two plastic pieces together rather than just holding the two pieces like super glue.
Thanks, I'll try that.
Try using PVC cement. I've used it on some plastic pieces in my refrigerator. I reinforced it with some scrap pieces of plastic.
'68 GTO '69 Corvette '75 Cadillac Coupe Deville TOM |
That I have at home, thanks.
Buy a plastic welder ; I have one I bought off Amazon ('bout a c-note) and it often makes the plastic stronger.
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
Use Plastic Weld 2 part epoxy. You can buy at O'reillys or Autozone. Get the one that sets up in a couple of minutes. Stuff is a miracle.
repair depends on what type of plastic they are made of.
sometimes solvent adhesives wont work and sometimes heat wont work. If you dont know what type of plastic it is look where theres a part # and see if its got the recycle triangle or a code like TPO, PVC,etc and look up the repair at this companies website. I have several solvent adhesives,hot air welder,plasticfix and still cant repair all the different types Ive run into http://www.urethanesupply.com/
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Certain plastics react well with methyl ethyl ketone, or m.e.k. pvc is one of them that should work, which is what I think interior trim is made of. Acetone works too, but I think it may be too "hot". m.e.k. dries slower and should give good results. It can be found at hardware stores. Rub it in with a qtip. This stuff really stinks, though.
X2 on the plastic welder. I bought one years ago from Matco, comes with different types of plastic "welding rods" .John
If i can get to the backside, i reinforce it with glass mat and fiberglass resin.
George
JB Weld. It's sandable, paintable. I use it everywhere.
'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed '66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed My Garage Tarheel Tigers Pontiac Club of Raleigh, NC |
X3 plastic welder.
Pat Brown |
try rapid fix
I tried PVC cement and it just stayed on the surface.
What is raipid fix? |
did you try to id the plastic and look up the recommended fix on website I provided?
I checked both the interior trim piece and the outdoor wheelbarrow/cart and neither had any identifying marks.
The products on that site are but pricey. Probably more for repair costs than the items are worth. |
you looked into their product called plastifix?
Ive used it on many things.
