Penny on motor
Any idea why someone would silicone a penny in a hole on the engine block under the intake?
Is this some sort of good luck thing or do I need to worry about it? |
Isn't that where the PCV valve goes?
'67 Piper Cherokee '66 Lemans |
That looks like the rubber grommet in the valley pan where the PCV valve goes. There should be a vaccum hose going from the PCV to the base of the carb or maybe in your case from the valve cover to the carb.
Thanks |
usually block the valve cover with a flat rubber grommet..just my 2 cents
Steve Karew |
Does most people put the pcv valve in the valley pan?
Stock location. I am more interested in the winters foundry casting on the intake
What do you mean?
What year Firebird? '67 has the PCV valve in the valley pan that vents to intake manifold and no vent tube from the passenger side valve cover - right? '68 and 9 had the PCV valve vented to intake and also vent pipe on passenger side valve cover to air cleaner.
I also saw the Winters foundry casting mark on the intake (next to thermostat housing on passenger side). What year is the engine?
1969 Firebird 400 Convertible "We have got but one life here. It pays, no matter what comes after it, to try and do things, to accomplish things in this life and not merely to have a soft and pleasant time." - Theodore Roosevelt "Light travels faster than sound. That is why some people appear to be bright until you hear them speak." - A father's words of wisdom to his children |
So I should remove the penny and route the PVC correctly? Is that recommended? |
If you remove the penny, you will decrease the value of the car.
69 Pontiac Firebird 400 convertible - project 69 Pontiac GTO 400 - sold 70 Buick Skylark 350 custom - project 72 Pontiac GTO 455 - sold |
lol
that was a good one Tony |
I removed it last night and I thought it would have been something if it was a 68 penny but no, they used a 1970.
