Old 03-27-2013, 12:44 AM
TonyE TonyE is offline
Default R/A III Carb question
Hey guys. Gotta question concerning carbs. On my 70 Judge (R/A III) I noticed I did not have the right carb #7040273. The carb was off a 70's Firebird. So I sold it and later bought a 70 GTO carb #7040262 that was on a 455. It is a 750 cfm. I do have the #'s matching cam,intake, and heads. I know the 7040262 is for a auto tranny and I do have a 4speed car. If the are both 750 cfm's what are the differences in the 2 performance wise? If I were to run the 7040262 for a while then switched to a 7040273 would there be a great deal of improvement? If so what would it take to make the 7040262 perform like the 7040273? Thanks
Old 03-27-2013, 04:15 AM
Kenth's Avatar
Kenth Kenth is offline
ALL 1970 RamAir M/T engines used the #7040273 Quadrajet, and so did your 1970 Judge.
#7040262 were used on 1970 Bonneville, no GTO used this Q-jet.
Both are 750cfm, but the 273 is much richer calibrated from idle tubes, idle channel restrictions, off-idle slots, main jetting and secondary emulsion tubes.
Also the 262 is more emission oriented using the primary POE-system for using leaner part-throttle jetting.
With all that said, both can be equal in performance once properly adjusted/modified in areas described above.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-29-2013, 05:36 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
What carb # did the standard 350 HP GTO 400 come with?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 03-29-2013, 06:07 PM
Kenth's Avatar
#7040263 for M/T and #7040264 for A/T.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 04-01-2013, 10:42 AM
^^Thanks!^^
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 04-01-2013, 06:27 PM
racerboy's Avatar
racerboy racerboy is offline
One minor addition. For MT RA III/IV cars built in California, the carb was 7040573. 7040570 for AT CA RA cars.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 04-01-2013, 08:31 PM
Half-Inch Stud's Avatar
my preference goes to the 7040262 about 5:1 in favor of the Off-idle pull & 60 foot capability. It's the top-plate, and seemingly easy to dial that sort of carb in.
