Old 03-28-2013, 07:16 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Talking What, no Camaro Z/28 thread?
NEW YORK – Chevrolet today introduced the restyled 2014 Camaro line at the New York Auto Show, including the return of the Z/28, the most iconic model in Camaro history.
The 2014 Camaro models feature a revised exterior design that integrates high-performance aerodynamics for more efficient cooling and stability at high speeds. The new Camaro Z/28 also features a full aerodynamics package that creates downforce at speed, which helps make it the most track-capable offering in Camaro’s history.
“As the ultimate track-capable Camaro, this car restores the mission of the original Z/28, and serves as a testament to the expertise of Chevrolet as the best-selling brand of performance cars,” said Mark Reuss, president, GM North America. “The build sheet is the wish list of any racer: lightweight, high-revving, dry-sump LS7 engine; carbon-ceramic brakes; integrated coolers for track use; true aerodynamic downforce, and a significant reduction in curb weight. This car could only come from Chevrolet, and could only be called the Z/28.”
The first Camaro Z/28 was introduced in 1967, created to compete in the Sports Car Club of America's Trans-Am 2 class. It featured a smaller, lighter, 302-cubic-inch V-8 for improved weight balance, as well as quick-ratio steering and a heavy-duty suspension for track use. In keeping with its road-racing focus, the 1967 Camaro Z/28 was not available with an automatic transmission or air conditioning.
While the new Camaro Z/28 is not intended to compete in a specific race series, it is solely focused on track capability. In initial testing, the Camaro Z/28 is three seconds faster per lap than the Camaro ZL1. That extra speed comes from three areas:
Increased grip: The Z/28 is capable of 1.05 g in cornering acceleration, due to comprehensive chassis revisions
Increased stopping power: the Z/28 features Brembo carbon-ceramic brakes capable of 1.5 g in deceleration, and consistent brake feel, lap after lap
Reduced curb weight: The naturally aspirated Z/28 weighs 300 pounds less than the supercharged Camaro ZL1, with changes ranging from lightweight wheels to thinner rear-window glass
Like the original, the 2014 Camaro Z/28 is offered only with a manual transmission. In a nod to modern convenience, air-conditioning is available, but only as an option.
"We set out to make the fastest road-racing Camaro possible that was still street-legal,” said Al Oppenheiser, Camaro chief engineer. “While the Camaro ZL1 offers exceptional performance on the street, the drag strip, and the track, the Z/28 is entirely focused on the track performance. The Z/28 will be too track-focused for most drivers, but offers road-racers one of the most capable track cars ever offered from an automaker.”
The new 2014 Camaro line will arrive at Chevrolet dealers later in 2013. The Camaro Z/28 is expected to be appearing at track events across the United States in spring 2014.
The racing-proven LS7 7.0L V-8 powers the all-new 2014 Camaro Z/28 – the most track-focused production model in the car’s history. It’s matched with a TREMEC TR6060 six-speed manual transmission with unique gearing tailored to the LS7’s performance characteristics for optimal track performance.
The Z/28 engine is adapted from the LS7 used in the C6 Corvette Z06, which was developed in conjunction with Corvette Racing. It is rated at an estimated 500 horsepower (373 kW) and 470 lb.-ft. of torque (637 Nm) in the new Camaro Z/28, with a maximum engine speed of 7,100 rpm – a broad rpm range that contributes to higher power and allows the driver to hold gears longer between shifts on the track. That helps keep the engine at peak power for quicker lap times.
“The LS7 lives on in the all-new Z/28, extending a performance legacy while delivering great power density in a lightweight package to give this exciting new Camaro a great feeling of control and balance,” said John Rydzewski, assistant chief engineer for small-block engines. “It introduced exotic materials and racing-influenced solutions that keep it at the forefront of high-performance technology.”
The LS7 is the most powerful naturally aspirated production engine ever from General Motors and, upon its launch in late 2005, was the first GM engine to receive SAE-certified power ratings.
“In the Camaro lineup, it complements a range of great V-8 choices, starting with the 426-horsepower LS3 in the Camaro SS and ending with the supercharged LSA rated at 580 horsepower in the Camaro ZL1,” said Rydzewski. “The LS7’s low mass and high rpm capability make it the perfect choice for the lightweight, track-capable Z/28, exemplifying all the strengths and attributes of the small-block architecture.”
Hand-assembled at GM’s Performance Build Center, in Wixom, Mich., the LS7 shares the basic Gen IV V-8 architecture as the Camaro SS’s 6.2L LS3 engine, but it uses a unique cylinder block casting with pressed-in steel cylinder liners to accommodate the engine’s larger diameter, 104.8mm cylinder bores – with deck-plate boring and honing for optimized bore geometry. It also uses a dry-sump oiling system to ensure full lubrication during the 1.05-g cornering loads the Z/28 is capable of producing.
Internally, the LS7’s reciprocating components use racing-derived lightweight technology, including titanium connecting rods and intake valves, to boost horsepower and rpm capability – and reduce overall engine mass. The titanium connecting rods provide perhaps the most direct link from the racetrack. They weigh just 464 grams apiece, almost 30 percent less than the rods in the LS3. Besides being lightweight, which enhances high-rpm performance and rpm range, titanium makes the rods extremely durable.
Additional engine highlight include:
Forged steel main bearing caps
Forged steel crankshaft
Titanium connecting rods with 101.6-mm stroke
Aluminum flat-top pistons
11.0:1 compression
High-lift camshaft
Racing-derived CNC-ported aluminum cylinder heads with titanium intake valves and sodium-filled exhaust valves
Hydroformed “tri-Y” exhaust manifolds
High-capacity, liquid-to-liquid oil cooling system
Unique cold-air induction system with low-restriction K&N air filter
Unique engine cover with “Camaro 427” identification.
The LS7 exhaust system for the Z/28 is unique and features a tri-Y header design to take advantage of the V-8’s firing order. Primary pipe pairings join cylinders one and five, then three and seven on the left bank, with cylinders two and four and six and eight paired on the right bank. At each bank, the primary pairings collect into a secondary Y, delivering a combination of pulse separation of adjacent firing cylinders and improved scavenging for the engine’s firing order of 1-8-7-2-6-5-4-3. A dual-mode exhaust system and large, three-inch-diameter pipes complement the manifolds’ tuning and low restriction. The optimized header and exhaust system improves torque and sound quality from the LS7 engine.
High-flow heads
The LS7’s CNC-ported aluminum cylinder heads are designed to meet the high airflow demands of the engine’s 7.0-liter displacement, as it ingests more than 100 cubic feet more air per minute than the LS3 V-8 – a nearly 20-percent increase in airflow. To process that airflow capability, a hydraulic roller camshaft with 15mm intake and exhaust valve lift is used to allow plenty of air to circulate in and out of the engine.
To ensure optimal, uninterrupted airflow, the LS7’s heads have straight, tunnel-like intake runners. Very large by production-vehicle standards – even racing standards – they are designed to maintain fast airflow velocity, providing excellent torque at low rpm and exhilarating horsepower at high rpm.
The heads feature 70cc combustion chambers that are fed by 56mm titanium intake valves, which are larger yet lighter than the valves in the LS3. They are partnered with 41mm sodium-filled exhaust valves, which feature hollow stems partially filled with a special sodium material that melts and liquefies around 205 degrees F (96 C). The inertia from the valves’ opening causes the liquefied sodium to move up inside the stem, dissipating heat better than a conventional exhaust valve.
To accommodate the large valve face diameters, the heads’ valve seats are Siamesed; and, taken from experience with the engines of Corvette race cars, the LS7’s valve angles are held at 12 degrees – vs. 15 degrees for the LS3 – to enhance airflow through the ports to get it into the combustions quicker and with less turbulence.
Dry-sump oiling system
A dry-sump oiling system is used with the LS7 and is designed to keep the engine fully lubricated during the high-cornering loads the Camaro Z/28 is capable of producing. A 10.5-quart reservoir delivers oil at a constant pressure to a conventional-style oil pump pick-up at the bottom of the engine. The pressurized oil feed keeps the oil pick-up continually immersed in oil at cornering loads exceeding 1.05 g.
Oil circulates through the engine and down to the oil pan, where it is sent back to the reservoir via a scavenge pump. The large-capacity reservoir, combined with a high efficiency air-to-oil cooler, provides necessary engine oil cooling under the demands of the engine’s power output. With the dry-sump system, oil is added to the engine via the reservoir tank – which includes the oil level dipstick.
Then and now
The engine in the original 1967 Z/28 was a 302-cubic-inch (4.9L) small-block rated at 290 horsepower and 290 lb-ft of torque. It was created by marrying the iron cylinder block of Chevrolet’s 283 V-8, which had 4.00-inch bores, with the crankshaft of the larger-displacement 327 engine, which delivered a 3.00-inch stroke, creating the 302-cubic-inch displacement that accommodated the engine-size regulation for SCCA’s Trans Am-2 class.
With its aluminum cylinder block and heads, as well as a composite intake manifold – and no heavy carburetor – the LS7 engine in the 2014 Camaro Z/28 weighs approximately 20 percent less and produces nearly 73 percent more horsepower than the 1967 302 engine.
Old 03-28-2013, 07:21 AM
Mr_GTO's Avatar
http://www.mediafire.com/view/?cin9wc9jiowe713
2014 Chevy Camaro Sales info
Old 03-28-2013, 07:51 AM
The Champ's Avatar
On my Camaro board we have a 5 page thread on it.
On this board mentioning the Camaro seems to be a lightning rod to the nabobs of negativity...
Old 03-28-2013, 07:59 AM
2002Z4CSS's Avatar
Nice car but way to expensive for most people. I remembver buying a 1978 Z28 brand new and yest it was more than a regular Camaro but still affordable for a working class person.
1971 Pontiac GT-37
Old 03-28-2013, 08:02 AM
Nothing exciting for me about this car.
Very few here bow down to the GM gods like you do. Im sure everyone would agree. Hense the reason for no thread.
Old 03-28-2013, 08:04 AM
Mr_GTO's Avatar
Yea but then again it isn't built for the masses. That's what the SS and 1LE are for.
Old 03-28-2013, 08:07 AM
Mr_GTO's Avatar
Well nothing shocking there. Do you like the way your TA handles? IF it's exciting to you then the Z/28 would be even more so.
Bow down? No....but I like to see that they are listening to the fan base and are bringing out cars that can compete with the competition. This car wasn't even on the radar to many folks in the CAMARO world because all the focus was on the slight redesign for '14. Seems GM is going to use lots of left over parts from the C6 ZO6/ZR1 to build this Camaro which is a win/win for everyone.
Old 03-28-2013, 08:27 AM
455Grandville's Avatar
455Grandville 455Grandville is offline
They sold plenty of Z-28s in the 70s-80s; I remember back then they were all over the place. When you get into that kind of money people then look at it as a Chevrolet and look at names with the pricetag, like Porsches.
It's a nice car, but you're correct; musclecars were supposed to be affordable for the common man, this one is more Wall Street priced.
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
Old 03-28-2013, 08:38 AM
Judge273's Avatar
Judge273 Judge273 is offline
I alway said theres the: Firebird vs Trans Am and the Camaro vs Z 28. Pontiac got that one right over Chevy. They are still trying to make something cool out of the Z 28.
ZL-1 is way cooler to me....
Mike/Illinois
Old 03-28-2013, 08:45 AM
The Champ's Avatar
The Z28's for most of the 70's and 80's were neutered cars wearing a Z28 logo. Nothing at all like the original Z's.
If you go back to the original Z28 - it was a very purpose built vehicle - similar to what the new one is today.
Comparing a '78 Z with 185 HP to the 2014 500 HP version is truly an apples/oranges deal.
In 1967 - you didn't see Z28's "all over the place". In 2014 you won't either.
As to the Z28 being priced like a Porsche - well if you want to compare a 255HP Porsche Boxter to a Z - then I guess you're right. If you're talking a 400+ HP 911 - well the Porsche will be about double the price.
Old 03-28-2013, 08:51 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I don`t know about ya`ll but, I keep seeing a `66 Caprice when looking at the rear.
Old 03-28-2013, 09:14 AM
bird72's Avatar
bird72 bird72 is offline
I wish ugly plastic covers that go on top of engines would be outlawed. And looking at that engine bay, that does not look like one designed to work on an engine, yikes. I bet it is fun to drive though. Looks? Did something change on it? It is alright, not ugly, sorta sporty and squashed looking, but not lines for the ages, like oh, a 70-73 bird
72 Bird
Old 03-28-2013, 09:20 AM
That and plastic wheelcovers. Whoever came up with those ideas should be tried for crimes against good taste.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 03-28-2013, 09:26 AM
Alvin's Avatar
Alvin Alvin is offline
Thanks for the picture; I was wondering where I'd seen those tail lights before!
Remember the 1975 & 76 Z28s? Right - there were none...but plenty of Trans Ams made and sold to fill the void (which many PYrs proudly own). Ultimately Chevy got the last laugh with the demise of Pontiac.
NaBob or not, makes no sense to me that GM would take an ingrained Z28 price point package to the consumer market and attempt to "create" another high water model. Sure, perhaps the intent is to emulate the 1969 offering which the retro styling is based, that makes sense.
However, as pointed out previous here, the sheer numbers of 2nd Gen Z28s sold from 1970 1/2 through 1981 water down any preconceived "new track performance" Z28 model IMO.
Ultimately it doesn't matter to me either way. Driving the current gen Camaro with the high doors and window slots make it something that I do NOT want to drive, and makes our 2nd Gen Birds (which are big cars by modern standards) seem smaller with more actual vision of the surroundings.
Old 03-28-2013, 09:43 AM
David Jones's Avatar
Ugly lipstick on a pig. A 3900 pound with NO A/C pig........
Old 03-28-2013, 09:47 AM
Alvin's Avatar
Talking
Mr. Jones, your post gave me quite a big laugh. Thank You Sir!
Old 03-28-2013, 09:49 AM
Mr_GTO's Avatar
GM didn't based it off the 70-81 models, nor the 2003-02 models. They based it off the original model which was meant for ROAD RACING.
I understand YOU don't want to drive it, but there are many others out there that do.
Old 03-28-2013, 09:52 AM
Mr_GTO's Avatar
And will still be quicker around a race track than any pontiac ever built.....
My guess is it will be a few seconds slower than the ZL1 around the 'ring.
Old 03-28-2013, 10:12 AM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
I actually see a little of the Volt in that back end.
Old 03-28-2013, 10:21 AM
Alvin's Avatar
Play with matches - Get burned! LOL
You knew at your first post that some here would not agree with you. For that you can find comrades on the aforementioned Camaro websites that are "creaming their jeans" for the Z no doubt. I can appreciate your bias and point of view. Your opinion is different than mine and the way I see it. Nice to be able to agree to disagree. No harm, no foul here IMO.
A$$ backwards marketing still holds here based on this previous marketing by Chebby:
1990s 1LEs were TRACK CARS...Z28s were mainstream "performance image" Camaros.
1998 - 2002 Z28s were - again - mainstream, with THE Z28 SS The SLP performance upgrade Camaro. And again IIRC 1LEs were "TRACK CAR CAMAROS", yes?
So, like I originally stated, GM Chebby marketing is ignoring their previous designation and hierarchy tier for the Z28 in the
2nd
3rd
4th
Generation which they have sold millions.
What's next - the Camaro Corvair Monza???
