Old 03-28-2013, 04:15 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Default Top Sportsman Turbo vs procharger?
I am knuckling back down on finishing my 70 gto top sportsman car and i am at the point to where I need to make a decision. 6 second ets are a must, but remember, we are still bracket racing. Curt geise has proven it can be done with a turbo, and big numbers. I'm not much of a boost guru. As a matter of fact, if you can't put a fuel jet, and a nitrous jet in it, I haven't done it. My biggest concern with a turbo car is staging and et consistency. I haven't really seen a similar style setup with a procharger yet, so I'm up in the air on both sides. Does anyone have any educated thoughts or opinions.
Race only
2600-2700#
Old 03-28-2013, 05:08 PM
Engo's Avatar
Engo Engo is offline
I have a friend that has been running a hemi with a procharger for 4-5 years. I think he has been around 6.50s at best lately. He has broke a LOT of parts along the way, cranks, blocks, rods... you name it. He has used only new and top notch parts.
You try and go that route with a Pontiac and I think you will break most everything you can break. And you will have a hard time getting into the sixes at all.
Staging a turbo car (with a auto) is not a big problem these days. Getting the right converter is the big problem and that will take some time to solve.
Consistent ets will come when your combo i sorted out just like any combo.
If consistency is important I would go EFI and turbo and alcohol for fuel.
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven.
https://www.facebook.com/photo.php?f...type=1&theater
Old 03-28-2013, 05:14 PM
Thank you
Old 03-28-2013, 08:19 PM
rodneybutler's Avatar
rodneybutler rodneybutler is offline
Give Travis Quillen a call before you make a final decision. 256-476-1053. He is doing big things with Pro Charger and mechanical injection. If you are a jet man, it might be the way to go.
Old 03-29-2013, 07:51 PM
Travis Q Travis Q is offline
Sixes at 2700 lb is going to take 2000 hp. Depending on cubic inches and head selection, you should be able to get there with either power adder.
Old 03-30-2013, 08:42 AM
If I go this route, i will be starting clean slate. I've always heard the turbos are much easier on parts, but are harder to tune and apply to the ground. I'm completely open minded at this point.
If I can't find a feasible way that I'm comfortable with , I'll build a n/a motor and go bracket racing.
Old 03-30-2013, 08:01 PM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
Default either or
Jr runs into the mids 6's with his F-3 procharged Grand prix. 522 Checy combo. car is very consistant. Im finishing up my Vortech car here soon. Chassis is good to 7.5 atm but the motor combo is capable of makeing over 2000 HP. Just car wont handle that much atm. There are a bunch of turbo cars that run with the WiseGuys that are 6 sec. cars but they do seem to either have a good run or and abort run, seems they alittle harder to drive. But guess its all in the set up
Old 03-30-2013, 11:30 PM
Here's some additional thoughts....
The power is going to be vastly easier to make with a turbocharged powerplant. Also, it will be a bunch easier on parts at this power level than a comparable ProCharger engine. The key to the whole deal is converter and gear ratios....everyone wants to put in a mega-tight converter to throw up a big MPH number, but a looser converter is easier to stage and will be more consistent on average tracks. The turbo combination can indeed be consistent; it's all about consistent boost control, as a small change in boost can equate to a big change in power/ET.
The downside to the turbo option is cost and complexity of the system. The Procharger powerplant is much easier to drive and easier to make consistent, without a doubt.
The Procharger system itself is also a little less expensive up front due to the lack of custom exhaust work.
The downside of the Procharger combination is that it takes a lot better engine components to make the power and have any sort of durability. A billet crank is mandatory, as are top of the line cylinder heads. A very good blower bracket system is necessary (5/8 and 3/4 thick brackets with 1" stands and B7 grade 7/16" studs are a must), as is a built-in crank support if a belt driven system is used (this will need to be incorporated into the blower brackets, as systems compatible with Roots/screw blowers won't work with a Procharger). You're also going to spin the engine a touch higher with a blower to make the combination happy, due to the camshaft profiles and converters used in these combinations.All this translates into more money on the engine side and more overall maintenance cost.
So, the question then becomes one of drivability, ease of tuning, overall cost, and maintenance levels.
The turbocharged combination, overall, is less expensive to build and to maintain.
The Procharged system, overall, is less of a hassle to tune and race.
Also, the cost of both total engine/power adder packages is pretty similar. For 2000 hp, you can expect to spend around $40-45K for the engine and its corresponting blower/turbo components. There will undoubtedly be those who will say "so-and-so did it for a lot less", but I can guarantee you that it's not going to be an apples to apples comparison. 2000 reliable, consistent HP out of a Pontiac with a blower or a turbo isn't going to be cheap. Can you make that power for less money? Sure. Is it going to run sixes at 2700 lb on every hit, on every track and be all-season-long reliable? Nope.
Old 03-31-2013, 06:17 PM
I agree with what your saying Travis. Since hes talking about TS racing. Which is still Bracket Racing. I think At this time The blower cars are alittle easier to keep consistant. But either way it takes time and $$$ to get either combo figured out. So its really the persons preferance on which way to go. I like both combinations. WOuld love to be able ot afford 2 cars 1 of each ;-)
Old 03-31-2013, 06:51 PM
Thank you for all the help and insight Travis .
Old 04-01-2013, 12:07 AM
Adam part of the reason turbo's are easier on parts is the drive method... A procharger engine will need 10 hp of drive for every 100 hp added... 2200 hp worth of mass air to net 2000... 200 hp gets eaten up by the drive... a turbo uses no crank power but instead normally wasted exhaust to drive it.
200 hp on the end of the crank and block that wasnt designed for that extra load makes some difference in reliability. That extra 200hp worth of air has to come from somewhere... as mentioned ...higher rpm is where most go to get that extra air... thus adding to the durability equation. The drive itself also needs to be durable.
Turbos using exhuast to drive things also have back pressure which tends to act as a shock absorber for the pistons... at both ends.
Past year or so there seems to be some great improvements in boost control/traction control software that helps from launch to top end. like any good effort it takes data logging to get a good read on whats going on and refine the tune.
Turbo's are load sensitive... more you load them the stronger they tend to come on... they usually dont need or want alot of gear... without good boost/traction control management your car can get slippery at the shift point even though it hooked hard at launch the pull after the shift can get interesting... Sure is interesting to watch a fast turbo car from mid track to finish...
Old 04-01-2013, 01:28 AM
Thank you bruce
Old 04-01-2013, 07:18 PM
Bruce, I'm not sure where your data comes from, but a friend of mine recently ran a 2400 hp capable blower on his blower dyno, and at max impeller rpm, it took nearly 500 hp to turn. That was making around 40 psi on a restriction that simulated a 632 inch engine. Thought you might find that interesting. The blower dyno results are backed up somewhat by the fact that a turbocharged engine of the same displacement at the same boost makes around 500 more hp at the flywheel at the same engine speed. The day we have centrifugal compressors capable of 2500+ hp that only take 200 hp to accelerate is the day that turbo manufacturers start to go broke!
Not true. The combination dictates ratio in a racing application, but the fastest cars are usually running lots more ratio than conventional thinking dictates. Think 5.14 in the rear....
Old 04-01-2013, 07:58 PM
Tom Vaught's Avatar
Boost Engineer
Well Travis, my little excel spreadsheet (compliments of Dave Austin and verified with the math & physics formulas) says that at 40 psi, 85 degree inlet air, 74% compressor efficiency, 12% parasitic losses, and the supercharger actually moving 240 lbs of air per minute (2400 horsepower) would suck up 505 horsepower.
I would say that we are in agreement on your post.
Tom Vaught
Bruce, that Rule of Thumb "10 hp of drive for every 100 hp added" or "One Hp to move One Pound of Air Mass and 1 lb air mass makes 10 hp" " only works for a pressure ratio of about 2 (15 psi boost) At 20 psi of boost you are talking around 120 hp to move 100 lbs of air mass. At 240 lbs/min you would be talking 300 HP. Raise the boost to 25 psi and you are around 150 hp for 100 lbs air mass. 350 hp to move that 240 lbs of air mass. You get the idea.
Old 04-01-2013, 08:12 PM
To add a little more to the discussion:
Something else to consider is that a pump, ANY pump, be it fuel, oil, or air, takes a given amount of horsepower to move a given amount of fluid at a given flow rate.
ACCELERATING this pump from a low flow rate to a higher flow rate takes a great deal more power than operating it at steady state. The faster you wish accelerate this pump, the more power it takes.
This is critically important when speaking about superchargers on race cars, because, unfortunately, they don't operate at steady state for very long. The faster we wish to accelerate the engine, the faster the blower must accelerate as well (it's tied to the crank snout, after all). And, since the power requirement to accelerate the blower increases non-linearly, that blower better be able to keep up when it's called upon.
Old 04-01-2013, 08:31 PM
Tom Vaught's Avatar
Boost Engineer
Nothing on a Boosted Engine is Free.
Belt stuff sucks up Horsepower at an amazing rate when actually raced on the drag strip. Bonneville stuff is a bit easier on things, as Travis mentioned, due to more time to accelerate up to max rpm. But there you have a Density & Temperature change to deal with.
Large PSI style Professional Superchargers consume massive amount of horsepower from the engine going down the track. Marty P's supercharger deal is HP thirsty for sure. Which makes his performance at Tucson Az so impressive.
I still think that we are learning more about boosting every day than any time in history other than pre-during WW-II.
Good Luck with your project Adam.
Tom Vaught
Old 04-01-2013, 08:40 PM
wreckmastr's Avatar
Subscribing
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 04-01-2013, 09:48 PM
Thanks Travis and Tom... I was workin the "rule of thumb" formula.
Turbine drive pressure or more importantly the amount of boost pressure vs exhaust pressure is a very key element to a successful turbo setup... Pressure differential has a big effect on how fast you can build hp and how much you can make. More discussion on that is always welcome.
Agree its amazing what is going on in the turbo world... My old ancient pair of "E" flow Rajay/Rotomasters were "bad boys" on a 350-400 inch engine back in the day(70's)... I think if you really push them maybe 900 max for the pair? If I find a usable turbine shaft for the bad one I may dust them off and find a home for them. Sure are compact and light. (Remind me of my wifes Kirby though )
Old 04-01-2013, 11:13 PM
Backpressure has no effect on how much power you can make, within reason. It has absolutely, positively, ZERO influence on the power number. NONE. While it is crucial to know how much backpressure that you're going to have, it is only so that other components, especially the camshaft, can be properly sized.
I have to laugh out loud when someone says to me that backpressure limits horsepower. The backpedals when I tell them that one of the fastest small block cars in history had over a 2 to 1 backpressure ratio are hilarious.
Old 04-01-2013, 11:48 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Just to add to Travis' comments, Here's my story...
$34K (includes turbos and fuel system) for the first engine with a home built set of headers, used EFI and the a set of junk e-heads. Rest of the parts are top of the line. Beg for all of the free data I can get, spend lots more money on a dyno, hurt the junk heads and still dont reach 2000hp.
Fast forward to today - Add another 11K for new heads, headers, intake, throttle body and cold side tubing all of which I will build myself.
Add another $2700 for a new EFI system, $4700-$6100 for injectors, and figure $2000 in AN fittings, hoses and various small parts.
Now after thats done add another $7000 for a trans, converter, cooler, and driveshaft.
And I still havent seen it make 2000hp or even know if I can make it reliable..... LOL!! (I'll get there this year...)
If I had any sense 2 years ago or would have listen to people I would have still spend $50K building the engine.
Your car is looking good, good luck with the build.
