Interchange question. What clutch (by application) will fit my 67 pressure plate, but a 26 spline T-5 input shaft? I'm using the same trans, etc. (85 T.A.?) from behind the 350 chevy I'm replacing in my 46 cpe. Nowhere near the power, but way cooler!
Should be a standard 10" clutch and pressure plate?
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
X2, I just called my favorate Clutch Manufacturer and ordered a 10" Disc & Pressure plate with the T-5's Spline count.
On a related issue do you have an F-body T-5? And if so how did you work out the 17 degree tilt issue? Just looking for ideas.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Hello All
Hello Jeff, in my 68 Firebird, I used a WC GM T5 main case, a WC Mustang tail shaft housing and shifter cover. Everything stands upright, and bolts up to the OHC 6 Bellhousing, there is only a slight angle to work with for the mount. I made an aluminum Wedge to correct for the angle for the mount, and modified a TH 400 crossmember for the OEM style mount to rest on. The reason I used a Mustang Tail Shaft Housing was to position the shifter where it would be properly positioned for me, The late model F body Shifter was too far to the rear, the S-10/15 was too far forward, the Mustang was just about perfect for me. Sounds a little like the goldie-locks story doesn't it I used the Mustang SVO 2.95 First Gearset too, you can get lower First gear sets but they are very hard on the main case, as in they have a tendency to break the case between the input and countershaft bearing bores. I have heard that 3rd gear is weak in the T-5's, but I never had any trouble with it myself. Hope this Helps, Take Care Dusty PS I can get the deminsions for the shifter hole on the Firebird if you need it, I have it stashed away someplace. PSS I would go with a 10.5 inch clutch, they are more common and have added holding power. The Centerforce Dual Friction Clutch is a good one, however it is a little hard to disengage at High RPM's like 6500-7200 RPM's. Last edited by BMFH; 04-09-2013 at 09:30 PM. |
My wife, a counter person at a major parts house, came up with the cure. The set from an 88 t.a. I was all messed up because I forgot that the 350 was from a truck with an 11 inch clutch. I had fabricated all the mounts etc. so the angle was built into the new cross member in my 46. The 350 was pretty healthy and pulling around a car the weight of a 46 cpe, I'd say the t-5 is up to the challenge. The only problem I had is, even after changing over to motor oil, it still shifts like a sissy. The position of the shifter from the f-body was not too bad in the 46. Thanks for the help gang.
Humm did you try synthetic ATF?
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
The trans had atf in it when I first got it. It really shifted easy. So easy, the leather boot from the previous trans. would pull the shifter into neutral every time you left off the gas. I guess i'm just used to trucks- and transmisions with linkage, not some teenagers honda. Did that sound old and bitter?
