Old 04-14-2013, 05:44 PM
fyrffytr1's Avatar
Default One More Timing Question
It's been a long time since I have set the timing on a car so have one question. From what I have read the initial timing is set with the car in Drive at 600rpm,vacuum advance disconnected and line plugged, is that correct?
Old 04-16-2013, 11:33 AM
cfd2bc's Avatar
cfd2bc cfd2bc is offline
Hello fellow FF. When I set the timing I do disconnect and plug the vac advance, but I leave it in park. When setting the idle, I do that in drive to the RPM I'm looking for. Hope that helps...
Jeff
Old 04-16-2013, 04:39 PM
fyrffytr1's Avatar
Do you set your idle rpm before or after the timing?
Old 04-16-2013, 04:55 PM
cfd2bc's Avatar
I set the idle to about what it should be, while it's in park 6-800 rpm. That is just a starting point because the idle speed will change when you set the timing. Then set the timing. Once you are happy there, set the idle. Then I check the timing again to to double check.
Hope that makes sense.
Jeff
Old 04-16-2013, 08:28 PM
fyrffytr1's Avatar
Maybe someone here should educate me on Manifold and ported vacuum. In the pictures you can see the vacuum sources I have available. Right now, the distributor is hooked to the port on the carb. Car idles smoothly, goes into gear easily and the tranny shifts smoothly. But, there is no difference in rpms when I hook the vacuum to this port.
Initial timing is at 12 degrees.
When I hook the vacuum line to the port on the intake manifold the car idles rough, goes into gear hard and shifts hard.
The only other vacuum sources on the carb are the one that the transmission is hooked to and the brake booster port on the back of the carb.
ID:	320040   Click image for larger version
Old 04-16-2013, 08:40 PM
cfd2bc's Avatar
Check out this link. Good info.
http://www.corvetteactioncenter.com/...m-advance.html
Old 04-17-2013, 09:32 AM
Rugratman's Avatar
Rugratman Rugratman is offline
I set the timing first, then the idle, as the idle speed will vary a bit.
The vacuum source for the dizzy, should not be a constant pull. Now, different carbs have different ports. Mine is a tripower....
I have fine tuned the timing with a vacuum gauge, with a constant pull...manifold vacuum.
Every engine is a bit different, cam, trans, etc.
Remember to plug the hose and the port, then set your timing, then reset the idle speed. Then fine tune it.
Custom curved the dizzy?
........I'm just learning as I go.......
Old 04-17-2013, 11:11 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
You can purchase from PY a carb bolt that secures the carb to the intake manifold, which has a rod that runs thru it and gives you another source for manifold vacuum. I use it on mine and installed on the driver side rear location on the carb spacer. I have my vacuum advance canister hooked up to it.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
