rear 8lug drum stuck on axle
Wow. I can't get the back 8lug drums off my driver. For certain, the drums have not been removed for 30+ years (car was in storage for 27 and the front pads were worn down).
Brake adjusters were backed off and then I started soaking with PB for 3-5 days. Using a shorty 3lb sledge and 2x4 block, i've been rapping at the back side of the hub by the backing plate in a circular motion. No luck.. Since then, I've soaked with corrosionX for 3 days and for the last few days I've been using Deadhead's recommended elixar (50/50 ATF and acetone) at the studs and around the axle center, turning periodically. This am, i put heat (map torch) to the drum around the studs and took another shot at it. Still no luck but maybe I didn't put enough heat on the drum. I have a large gear puller at the farm i'll be bringing back tomorrow that might do the trick but I don't want to destroy these hubs. The linings were excellent in front. Anyone faced this dilemma and if so, how did you get them off without destroying your aluminum hubs? |
I've run into the same problem several times parting out old Pontiacs so I made an 8 lug puller out of an old rusty rim, two pieces of strap, and a large fine thread nut and bolt.
The process that works best for me is to heat each of the five center lug bolts cherry red several times with an oxy/acetelene torch (put the flame directly on the end of the bolts one after the other), and then I mount the puller, place a block of steel between the hub and bolt that pulls the puller/drum off, and start turning the bolt in. The frozen drums have come off every time sometimes easy and sometimes POW when it lets loose. |
(Hopefully I'll never need to do anything like that) K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
It MIGHT be that the brake shoes have cut a ridge in the drum thus preventing the drum from sliding off. Has happened to me several times. I just wrestled the drum with a couple of pry bars until the drum popped off.
I really like 61-63s puller...red neck engineering at its best !! Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
drums
if the cars drivable put wheels back on and leave axle lugnuts hand tight or a few turns looser drive it making sharp lefts and rights they should pop. i do this all the time from cars to our tandem dump trucks. good luck.
Keep the suggestions flowin. 61-63, wish you were across town. i'd rent it from you. that is absolutely garage engineering at its best. i might have an old 8lug'er up at the farm. nothing here i'm willing to sacrifice. gotta have a spair. this car has yet to be "re"licensed but i did try 62cat's method for a couple of miles as well. but, more straight on driving than anything as i'm still working the bugs out of her after many years of inactivity. there's a couple local PY'ers here local that might have have an old rim layin around. if i don't find a rim tomorrow, i'll send them PMs unless someone out there has a PLAN B.
My front 5 lug iron drum is stuck on as well..one of these days I gotta unstuck it.
66 Bonneville - 389, Holley powered |
When extracting the drum, swearing helps.
Stu Norman Msgt. (ret) Hortonville WI May the torque be with you. |
You may know this but Harbor Freight and others sell conventional pullers that will take that one off. You can rent them from O'Reilly's and their sister stores.
wrong shoes!!!!!!!!!!1
It's because they installed the wrong shoes, they put on narrower ones and they make one hell of a lip. Don't ask me how I know.
Greg |
61-63 gets this week's "great tech trophy" (if we had one).
ho421, FedEx even delivers to Springfield! ...why not work out a rental with 61-63? Damn narrow shoes! What are they, '65+? |
incorrect shoes hurt the feet.
Matt,
I think they order the standard shoes and do not specify 8 lug wheels, or the counter guy doesn't ask. They then get the right shoes for regular wheel cars and put them on the 8 lugs wheels. Greg |
John and I have had a side conversation. ;-)
I think I have an extra rim, I am only 1 hour away. If worst comes to worst, I have three 1963 rear drums, one for sure is left hand threads. Thanks, Rex
1962 Catalina 421 Tripower 4-speed "Red" 1962 Grand Prix 389 Tripower 4-speed "White" 1962 Corvette 402hp 350 4-speed 2009 GMC Yukon Denali 2011 GMC Yukon Denali |
Sometimes towed but never trailered! Last edited by MOJO Catalina; 05-03-2013 at 09:51 AM. |
So Bob did you manage to gently persuade that rim to let go?
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool |
Not yet but john's puller showed up at my door late yesterday.
Verdict. 61-63's puller is the cat's meow. In less than an hour, both drums are off. That puller showed those drums who's the bossman. Corrosion and as expected, shoes cut grooves in the lining. Hats off to john for coming up with the tool and the willingness to send it to someone he's never spoken with. Much thanks.
It is amazing just how STUCK those SOBs can get! Parted out a 65 Buick Wildcat years ago, it had the heavy duty finned aluminum drums on front, but had sat unmoved, outside from 1978 to 2003. I gave up trying to get them off, it wasn't worth the pain.
