Old 05-07-2013, 08:07 AM
70gteeo's Avatar
70gteeo 70gteeo is offline
Default 67 Firebird 400 conv. w/AC Need rear springs
There are so many options on the market today that I am just not sure what would work best for my Firebird.
I will be driving the car around town only will not be racing. I want ride comfort and as little wheel hop as possible.
Eaton has the mono leaf springs that my car came with. Does anyone know of how good they are?
Eaton also has a conversion for the 67 firebird to be able to use multi leaf springs. Has anyone tried this and how good is the ride.
Also HOTCHKIS® 2407C - 1.5" Rear Lowering Leaf Springs (Multi) how is the ride with this set-up? Also I have the stock height front spring that I got from Ames would I have to change out the front spring to go with lowering the rear springs?
Thanks guys for your answers, Steve
The first betrayal is what they did to you.
The second betrayal is what you do to yourself.
1967 Firebird 400 convertible 4 speed #'s matching
2002 SOM Trans Am WS6 Convertible 6 speed bone stock
1970 GTO convertible auto #'s matching
Old 05-07-2013, 10:55 AM
68tpls400 68tpls400 is offline
I put new Eaton monos on my '67 about six years ago. (I restored to stock condition) Other than ride height about 1" too high, I was happy with them. They settled about 1/2" over the following two years. I don't know about your other questions. I purchased the Eatons through NPD. (their prices were lower than buying direct from Eaton. Go figure!)
Old 05-12-2013, 05:28 PM
JUDGEMAN70 JUDGEMAN70 is offline
I put the Eaton mono springs on my 67 convert. and they looked horrible unless you like the jacked up look in the rear. Ordered some from tamzas in Illinois. not sure the name brand name but were much more correct for ride height.
Old 05-12-2013, 08:24 PM
Cammer-6 Cammer-6 is offline
Eaton will make the springs about any height or load rating if you want to change it.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
