(2) 12 bolt rear ends one out of a 70 GTO no center section $700.00 on out a 71 Chevelle $850.00.
NOS Hurst Dual Gate Shifter Cable $175.00 Hurst Dual Gate Shifter Harness $40.00 NOS A/C Delco Plugs 45's sets $60.00 while they last, NOS A/C Delco PVC $8.00, NOS SLOTTED NUTS, CORRECT FOR ENGINE COMPARTMENT- SET OF 5 FOR $25.00 Oil sending units for rally gauge set up $35.00 Water temp sending unit $40.00 68-69 NOS FRONT WINDSHEILD UPPER STAINLESS MOLDING $150.00 68-69 NOS Driver's side front window molding $90.00 68-69 New Pr. of tail pipes 2 1/4 inch $100.00 68-69 Waldron 2 1/4 stock exhaust system bolt on but never driven $300.00 69-72 AM&FM RADIO PULLED OUT OF A JUDGE IN 1983 works $475.00 69 AM RADIO works $200.00 65-66 rear bumper lens $7.00 66-67 miscellaneous moldings early style harmonic balancer parts fast idle solenoid $100.00 68 Lemans 2 speed shifter bezel $25.00 In dash wiring harness $40.00 68 driver's side vent window and frame $50.00 68-69 Front window 3pc stainless moldings $125.00 68-69 front lower window reveal molding $60.00 68-69 front fender rear chrome moldings (2 sets)$30.00 pr. 68-69 rear bumper rubber snubbers $30.00 pr. 68-69 alternator bracket that bolts to front of water pump $20.00, 68 1/4 panel side markers, lenses, bezels and housings $40.00 pr., 69-72 Goldenrod/Tan & Pewter/Gray steering wheels crack free $125.00 68 & 69 LEMANS Front Bumper Grill Brackets $35.00 pr. 68 & 69 non hideway frame to bumper brackets $65.00 68-69 door vents pr. $20.00 68-71 gas pedal & bracket assembly $50.00, 68-72 positive battery to starter heat shield tube, 68-72 1/4 window glass chrome trim moldings $30.00 pr. fuel escentrics $35.00 68-72 single A/C crank pulleys $35.00, 68-72 A/C compressors $50.00 68-72 A/C assorted brackets oil filter housing $60.00 68 driver side door glass $65.00 68 driver side vent window with frame $65.00 68-72 emergency brake cable set up $100.00 68-72 emergency brake pedal and bracket $50.00 68-72 rear license plate bracket and holder $35.00, 68-72 rear view mirror $25.00 68 rear bumper brackets $65.00 68-72 front armrest bases black $25.00pr, 68-72 door glass & 1/4 glass regulators $50.00 68-72 hardtop crossmembers primed and painted $90.00 69-72 auto shifters standard & rachet style only a few left 68-72 shifter bezels - 68 2 speed auto bezel, 69-72 3 speed auto bezels $25.00-$35.00 68-72 water thermostat housings $15.00 , 68-72 door hinges $50.00 68-72 points distributors no RA one left $80.00 68-72 wiper tranmission assembly $50.00 69-72 harmonic balancer $30.00, 1977 Harmonic balancer with less than 500 miles $50.00 68-72 blower motors $25.00 68-72 a/c inner and outer boxes with blower motor and heat cores $150.00, 68-72 inner heater box $150.00 68-69 headliner bows $50.00 set 68-72 coils & brackets $35.00 68-72 windage trays $45.00 valley pans $35.00 flex plates $35.00 68-72 stock blue valve covers $25.00 a set 69-72 Gauge&Speedometer cluster $65.00 69-72 Rally Gauge set up $150.00 69-72 Power Front Disk Master Cylinder like new, used during restoration $45.00 assorted stainless moldings, 15x7 Rally II wheels reproductions good condition $175.00 pr. 69-72 ac & heater dash control with cable $135.00, 69-72 clock delete dash cover $15.00 68-72 door vents pr. $20.00 68-74 power brake booster $50.00, used original Pontiac oil pans $40.00-$65.00 72 & 73 400 SHORT BLOCKS $500.00, 70 WT GTO 400 SHORT BLOCK $1400.00 Torker intake $150.00, MSD BASTER II COIL $25.00 B&M 2000 CONVERTER $125.00 LESS THAN 100 MILES aftermarket chrome valve covers Elderbrock $40.00, a set MALLORY 7MM SUPPRESSION SPARK PLUG WIRES $25.00, AFTERMARKET FLEX FAN $15.00, new points and condensers E-mail at [email protected] __________________ Timmy __________________
Timmy Mallory |
NOS Hurst Dual Gate Shifter Cable has been sold!
Timmy Mallory |
Do you have a good clean, straight blue valve cover set? Do they have a oil fill cap?
1oldgoat I believe I do, if you E-mail me at [email protected] and I'll get you pictures of the valve covers and oil filler cap.
Timmy Mallory |
Hello,
I'm interested in the rear view mirror if it is right for a '68 Bonneville. Not sure they were different. Thanks! |
What year are the oil sending units for rally gauges?
hello timmt, sent you a pm
PM sent to Carl A and Mark Martin
Timmy Mallory |
I'll take a good oil sending unit for a 71 with rally gauges.
1oldgoat, I'll pull one a oil sending unit out for you. If you E-mail me at [email protected] I'll get you pictures of the rest of the stuff you ask for. Thanks Timmy
Timmy Mallory |
Stock blue valve covers have been sold!
Timmy Mallory |
pm sent timmy
do you still have crossmembers?
1963 Tempest 1969 Pro Touring GTO All Aluminum 505 IA, 4L80, Roadster Shop Chassis 2004 GRAND AM TUBE CHASSIS RACE CAR 505 IA II 7.92@173 |
