Old 05-13-2013, 08:42 PM
DOC DOC is offline
Default Install 1st question 69 firebird???
getting ready to start assembling the front end headlights/entire nose etc.... and was wondering if i need to install the hood 1st? any recommendations?
Old 05-13-2013, 11:04 PM
Firebob's Avatar
Firebob Firebob is offline
You don't have to but if you want to make sure there isn't too much gap between the batwing and the front of the hood it's better to have it on first.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 05-14-2013, 09:55 PM
GoatandBirdCollector GoatandBirdCollector is offline
The hood helps with the front gap alignment@ the nose.
Just allow extra time & be ready to walk away a few times for a sanity break.
Old 05-14-2013, 10:02 PM
DOC DOC is offline
I figure w/ my ADHD I will start the nose, see a squirrel, start messing with the console, see another squirrel the start on wiring the trunk... hahahahaha. I do appreciate the advice and hopefully get it done within 1 day.
Old 05-15-2013, 09:46 PM
gemdiam gemdiam is offline
It's a total nightmare
Old 05-16-2013, 06:35 AM
Birdguy's Avatar
Birdguy Birdguy is offline
You sound exactly like me! This is the perfect hobby for our "gift".
Old 05-17-2013, 06:10 PM
Schoust's Avatar
Schoust Schoust is offline
Hmm must run with this sort of Hobby....
Old 05-22-2013, 04:16 PM
Reassembled mine last year after the repaint;
Rust free and never accidented car
front clip never previously removed and fit perfectly before painting
every bolt, nut and clip bagged and labelled
piles of before and during dis assembly photos
And it was still hell!!! We screwed with it for days and days trying to get it right. What in gods name were they thinking when they designed this front end?
Old 05-27-2013, 09:04 PM
DOC DOC is offline
spent 1 1/2 days on the front end this weekend. no farther ahead than what I started with. getting a second set of eyes to help later in the week.
Old 05-27-2013, 09:26 PM
Yes , misery loves company!
I'm convinced it's what caused the GM strike in '69.
It's amazing that the line workers got so many put together half right!
GOOD LUCK!
Old 05-28-2013, 10:56 AM
steveK steveK is offline
Patience...when you get pissed, walk away. I think I walked well over 100 miles when I did mine over. Fortunatly I did it over 6 winter months in a heated garage!!
Steve Karew
Old 05-28-2013, 11:09 AM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Well this is encouraging lol
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 05-28-2013, 06:12 PM
sts sts is offline
<It's amazing that the line workers got so many put together half right!>
They had them right on every car that left the factory. I knew it couldn't be complicated or require a high skill level because it came off an assembly line. It's just like many other assemblies where you are required to use a specific order when locating, installing, and tightening fasteners. (The water neck bolt in an intake is a good example.) Once you know how they assembed it at the factory, it simply falls onto the car.
I took a look at the limited body information in the service manual. I think that the goat works the same way, meaning this would also be contribting factor for their ill fits. As soon as I get it together and hit the crusie lot, I'm going goat hunting, and see if I can get an eyeball on various parts.
