Old 05-20-2013, 08:42 PM
Bob Bowman 1968's Avatar
Bob Bowman 1968 Bob Bowman 1968 is offline
Default 67 Firebird rearend open to posi
I am working on a 1967 Firebird that has a 326 in it. We are adding a four speed automatic transmission. The rear end in it is an open 2.56 which is too high for fourth gear. The rear end is stamped XB. It has the mono leaf spring perches and factory traction bars. 8.2 rear end. We are looking for a posi unit that we could use 3.73 gears with. Does Auburn, Eaton, or Dana make a posi carrier that will fit into the original rear end housing? We have been told that the housing will not work with lower gear sets. The car is not going to be raced. Going to run street tires and do a burn out one in awhile. Not worried about the strength of the 8.2 since it's going to be a street car and not drag raced. Any advice or thoughts?
Old 05-20-2013, 08:48 PM
The axle housing itself will accept any factory or aftermarket 8.2" posi unit you want to put in it, you've been misinformed.
Put the tough Eaton posi in it, it will accept 3.36 and higher gears numerically (your 3.73s will work of course).
Old 05-20-2013, 10:17 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
X 2 on the Eaton.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 05-22-2013, 01:08 PM
1stgenbird's Avatar
1stgenbird 1stgenbird is offline
I have seen QP brand on ebay that say they are "Eaton style" and less cost than Eaton. Any experience with this brand?
Old 05-22-2013, 01:41 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
Default 8.2
I have a factory posi unit with 3.36 gears if your interested!
Old 05-22-2013, 01:58 PM
1stgenbird's Avatar
PM sent
Old 05-22-2013, 09:21 PM
71SportRagtop's Avatar
71SportRagtop 71SportRagtop is offline
Next in line...PM sent
Greg
68 Firebird Verdoro Green
428, 6X-4 heads, Comp XE284 cam
Muncie 4 speed
3:73 rear
