I have a bunch of the quarter ornaments but they need re-chroming. Are the current repops ok or should I look into re-chroming a set ??
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
There are good repops and there are bad repops. Here's a thread on that topic:
http://forums.maxperformanceinc.com/...d.php?t=669245 Edit: I found the pictures I took but not the article I wrote. Here's the most compelling reasons NOT to buy the cheap ones. The studs are the wrong spacing and the shape is different: ![]() This pic shows the difference in thickness, finish and stud length between the two: ![]() The good ones are from Trimparts
68 GTO ragtop 91 T/A 69 XKE Last edited by fyrebird68; 05-23-2013 at 09:03 AM. |
