Old 06-07-2013, 01:30 PM
dci dci is offline
Angry DCI MOTORSPORTS RAM AIR 5 Intake
I am having a real tough time with pulling the trigger on this single four intake for my 5 heads. Because I have so many guy's wanting this to fit under the hood.I am going to do it, but the intake in my opinion is going to limit my heads ability to perform. Take a look at the drawings and see what you think. I feel the intake is to flat ,but I cannot go any higher or it will not fit under a stock hood. I really do not like the thought of investing so much money into a turd. If it didn't cost so much, it would not bother me so much.
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads!!!!!!
ID:	325631   Click image for larger version
ID:	325632   Click image for larger version
Old 06-07-2013, 01:35 PM
tom s tom s is offline
If it wont bolt up to a stock set of heads without any work along with a water X over I think your wasting your money!JMHO,Tom
Old 06-07-2013, 01:38 PM
quicksilver97ta's Avatar
Those guys obviously want the cool factor, that is to say, it's a matter of priorities. Thats cool... Is it the carb or the air cleaner that interferes with the stock hood? Is there not enough clearance to make the intake taller and just mandate the use of a drop base air cleaner?
Old 06-07-2013, 01:45 PM
dci dci is offline
To be honest, I'm not really trying to appeal to that market. The factory heads are so hard to come by, and the guy's other than yourself and a hand full of others don't use the heads anyway. It seems like most of the guy's I know that have the heads. Would rather keep them in boxes on the shelf and just use them for conversation sake. I know were there are several sets, but they are not on engines. So I think that if I made it to fit them that I would be wasting my money. Not saying that my intake could not be made to work on factory heads. It's just not my target audience.
Don Johnston
330-850-5050 shop
330-628-3354 cell
Old 06-07-2013, 01:48 PM
rad400 rad400 is offline
Don it might fit with a good drop in the base or like my dude scoop from Keefer and a frop base.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 06-07-2013, 01:52 PM
dci dci is offline
quicksilver97ta, I did cheat it up a little higher than a factory quadrajet intake by 3/4", but it is still to low in my opinion. I'm trying to keep it low enough that someone with a Trans Am could still use their shaker scoop. And I think your right, the street guy's are more interested in the cool factor not all out performance.
Don Johnston
330-850-5050 shop
330-628-3354 cell
Old 06-07-2013, 02:35 PM
Brian Baker's Avatar
I agree. Make it so it will work with OEM heads and fit under the hood and don't worry about it choking the heads. If someone wants to unleash their potential, they'll contact someone like Wilson.
Old 06-07-2013, 02:45 PM
s2k1 s2k1 is offline
If I were putting these heads on one of my GTOs and wanted to keep everything under the hood, I would build a custom cross ram EFI setup with individual throttle bodies. That's just me.
1964 GTO Hardtop Black/Black
1964 GTO Sedan Black/Black
1969 Grand Prix Model J
1972 GMC K20 427/TH350
1972 Chevy C30 FlatBed 402/TH400
1972 GMC C10 350/TH350
Old 06-07-2013, 02:58 PM
ho428's Avatar
ho428 ho428 is offline
You know me Don, I really want a dual quad... But either way it's got to fit under the hood or people like me won't buy it.
I run a Northwind with a drop base and it fits under a FGF hood even with a 1/4" spacer.
What the NW won't do is fit under a second gen. So you might have to make a car body decision if you want performance height under the hood.
Old 06-07-2013, 03:03 PM
Sirrotica's Avatar
Don, if I spend the money on the redesigned V heads, I would definitely not want them choked by the limiting factor of an intake that has to fit under a stock hood. The factory already made that concession and according to dyno tests the factory V intake really holds the factory iron heads back.
With the raised ports your heads have there is probably only going to be one intake made and I'd like to see it made for utmost performance, not fitting under a stock hood.
Is there any chance the carb base could be made similar to the KRE Northwind that could be milled for clearance at the owners discretion knowing that they will give up some power by doing so.
If your going to make it to fit under a stock hood you might as well make it for a Q-jet base too.................................LOL
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-07-2013, 03:19 PM
Don,Lynn's single is very good and pretty much what your going to make!
Old 06-07-2013, 06:12 PM
Tom Vaught's Avatar
Boost Engineer
That would be my vote too. A LOT of guys are looking into EFI these days and the cross-ram would fit that need (as would a low profile EFI 4-BBL Throttle-Body and a higher intake runner design).
So I would not give up on doing a more developed FUNCTIONAL vs restricted) intake manifold design. Anyone that spends the money to buy your RAV split port heads will have the money for a EFI set-up and still have lots of bragging rights (that it is a RAV type design. You said you are not catering to the stock RAV guys. Cater to the state of the art Pontiac guys who want latest high tech with old school roots.
Tom Vaught
Old 06-07-2013, 06:34 PM
mgarblik mgarblik is offline
Up until Tom's post, I had not really considered EFI. But why not? Lots of advantages there for a street car and the lousy high vapor pressure pump gas. A cross ram EFI would be really cool. For my personal use, keeping it all under a stock hood is a must. I wouldn't cut up my original muscle car with a hood scoop. I like the appeal of stock looking and a killer engine hidden under the hood. As said, the manifold needs to work too. A tough situation with tall heads and low hoods.
Old 06-07-2013, 06:35 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Will McCarty's intake fit your heads and stock V heads without major modification and will it make reasonable power?
In my opinion, your target market for aftermarket RA-V heads fitting under a stock hood is going to be extremely limited.
You should not compromise your intake design to fit under a stock hood. If it fits McCarty's heads, and is EFI ready, I'll take 1.
Do you need an intake to test fit with your heads?
How close are your exhaust ports/header bolt locations to McCartys V heads?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 06-07-2013, 07:32 PM
Tom Vaught
Sorry for the Hi-jack Don!
On subject, I too think you should make the intake for optimum performance, and not worry about the hood height.
As for the cross ram, how about something like one of these?
Old 06-07-2013, 07:57 PM
67copperbird 67copperbird is offline
I will play the devil's advocate and say "make a short deck block" then you could have a taller intake. Problem solved.
Ben Mowery
Old 06-07-2013, 08:08 PM
a custom converted ford tunnel port single 4 made 30 HP over a stock intake!It was the same height as the stock intake.That was with just a intake change with same carb and no tuning.It is worth the change IMO.Tom
Old 06-07-2013, 08:09 PM
Don I personally think that folks who want a tall single plane or dual fours would spring for a custom intake. For my application I will need something that fits under the hood. If that means having an intake made than that's what it means. I would let the folks who buy them drive your market.
Ben Mowery
Old 06-07-2013, 08:36 PM
Tom Vaught's Avatar
Boost Engineer
The 2nd picture posted by s2k1 would be fairly easy to cast up as it is actually 2 runners systems. Do the work properly and would could use one mold for both sides if you got the stagger right.
Tom Vaught
Old 06-07-2013, 08:54 PM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
If I were spending the the money to put a RamAirV in my Firebird or GTO I would not worry about the hood clearance. I would want the best intake manifold you could make. I would make the adjustment with a cowl induction style hood. The RAV is not original to the car, so why worry about using an original hood. Just my 2cents.
