1966 Longtail Transmission Mount?
I have a longtail Muncie in my 66 Bonneville wagon and am trying to find a transmission mount. The local NAPA has had zero luck and says they have never seen one like it.
It's got a single stud that bolts to the cross-member and then two holes for the trans. The issue is that the holes are offset (diagonal) by about an inch. I have not been able to find one that looks like it. Does the long tail shaft have a different mount than the standard? I'll try to post a picture of it tomorrow... Found this after I posted... here is on on ebay... http://www.ebay.com/itm/WESTAR-EM-23...d9770c&vxp=mtr
Thad 1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver 1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!! |
That should be what you need.
Or you can check with our host Performance Years. Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
I'll see if I can find the part number, but I used a trans mount from a 66 mustang I believe. Maybe search "mustang mount" here
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
Go to a parts store and get a 2333 mount, which is an engine mount for a 6 cylinder Mustang. It works perfect.
I think that the correct part # is 2321. It fits all 1965-1970 Full Size Pontiacs, Automatic or Manual transmission. It does appear to sit crooked with the factory mount, but will sit squarely with the Ford mount.
yup, thats the one. Just put mine in a few weeks ago, works great and is the right size!!
I ended up ordering the 2321. The Ford mount looks to have the holes in line with the stud, while mine has them offset. I looked at my transmission and it definitely has offset holes so the Ford mount would have been crooked. It would have worked though.
No, the Ford mount is straight, as it was in 1965. In 1966, they staggered the mount.
I have done this many times.
