Old 06-23-2013, 05:25 PM
JJake JJake is offline
Default Firebird Speedocable
Is there any way to eliminate the intermediate box between the upper and lower speedometer cables on a 1979 TA?
Old 06-25-2013, 06:22 AM
Don 79 TA Don 79 TA is offline
you mean the part for the cruise control?
i just swapped in one longer cable, its been some 20 years since i did it so i dont remember off hand what it was
i dont remember if i got it from GM at the time or the auto parts store (when there really were auto parts stores and auto parts counter people)
i had to do that when i swapped from the auto to the 4spd, then i swapped to the 5spd
Old 06-25-2013, 10:03 AM
Thanks, I'll look for an 80 inch + cable with the correct ends.
Old 06-25-2013, 10:40 AM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
If its like a '78 then you can just buy a cable for a car w/o cruize
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 06-25-2013, 03:15 PM
track73 track73 is offline
My '79 T/A had a 2 piece cable and no Cruise control.
Old 06-25-2013, 03:31 PM
Maybe a one piece cable from a '78 would fit?
Old 06-25-2013, 11:04 PM
Grand73Am Grand73Am is offline
Was it a 4 speed? I believe the 4 speeds use a 2 piece cable with some kind of connector/adapter in between the cables.
I believe a 79 automatic without cruise just has one cable.
Steve F.
