Old 06-25-2013, 10:59 PM
dennis kirban dennis kirban is offline
PY VIP
Default Next Mini Contest
I figured I would squeeze one more contest in prior to the GTO/POCI Nats. Hope to see many of you there as I am a guest speaker plus I will have a small indoor vendor spot. Pete Serio will be also with me. Pete has been a long time personal friend of mine for over 30 years.
The prize for this contest is a discontinued printed on two sides full color GTO T shirt. Pretty certain I can match the size you want if you win.
Players: open to one and all.
Number of guesses you can take 3 shots.
Post your answer in this thread. First one that matches the answer I want is the winner.
Here are the clues:
While several answers may be correct, you got to pick the answer I am seeking. Once the correct answer is given I will post photographic proof as I got this item(s)? still factory sealed in the wrapper.
Every GTO uses this item
It is engine related
Its a part that appears at one time was offered reconditioned/rebuilt but you never see them reconditioned/rebuilt today.
What is the EXACT part I am referring to.
The one I have covers up to 1966 so it was offered at least thru the 1966 model year.
Again I have proof.
If you play you can take 3 guesses.
You got to nail down the item I am referring to in order to be declared the winner.
Good luck players.
[email protected]
By the way at my seminar I will be passing out a free DVD as long a supplies last. So not only can you get inside out of the heat but get something free. I am speaking on Hurst and early GTO reproductions and the stories behind them.
Old 06-26-2013, 12:47 AM
Carter Fuel Pump
btw - got the Hurst Hat and stuff
Super Cool !
Old 06-26-2013, 02:14 AM
cuz68's Avatar
cuz68 cuz68 is offline
Wink
Lifters,Timing chain.
Cuz68
Old 06-26-2013, 03:21 AM
thadeal4real thadeal4real is offline
how about a 326 motor
"The democracy will cease to exist
when you take away from those who are willing to work
and give to those who would not."
Thomas Jefferson
Old 06-26-2013, 06:21 AM
Cerberus's Avatar
Cerberus Cerberus is offline
A driver.
Old 06-26-2013, 06:44 AM
Tim john Tim john is offline
water pump
Tj
Old 06-26-2013, 07:15 AM
Camshaft (regrind)
Old 06-26-2013, 07:16 AM
Last shot
Oil Pump
Old 06-26-2013, 08:10 AM
2cdavis3's Avatar
2cdavis3 2cdavis3 is offline
ignition coil
Old 06-26-2013, 08:40 AM
Master cylinder ?
Wheel cylinders ?
Tj
Old 06-26-2013, 09:19 AM
gregneun gregneun is offline
Default engine
389's
Old 06-26-2013, 09:39 AM
1969GTO's Avatar
1969GTO 1969GTO is offline
Oil Pressure switch
Manifold Vacuum Switch
Distributor Control Valve
color me gone
Old 06-26-2013, 09:55 AM
barrierblue66's Avatar
barrierblue66 barrierblue66 is offline
Heat riser
'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed
'66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed
My Garage
Tarheel Tigers Pontiac Club of Raleigh, NC
Old 06-26-2013, 10:56 AM
GTO68FXSTC98's Avatar
GTO68FXSTC98 GTO68FXSTC98 is offline
alternator
starter motor
wiper motor
Old 06-26-2013, 11:13 AM
Alvin's Avatar
Alvin Alvin is offline
Carburetor
Old 06-26-2013, 12:37 PM
Radiator/heater core?
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 06-26-2013, 12:44 PM
Fan clutch
My Garage
Old 06-26-2013, 01:04 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Ignition Distributor
Regards,
"455HO" Lloyd
Old 06-26-2013, 01:08 PM
6704gto's Avatar
6704gto 6704gto is offline
chrome valave covers
Old 06-26-2013, 04:38 PM
GT182's Avatar
GT182 GT182 is offline
A very wild guess....
The firewall's Delco voltage regulator.
Hey, I said it was a wild guess.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
