... we just recently completed a 461c.i. 455HO engine for a customer, and we thought it was a pretty nice build, the same engine before made about 440hp according to the customer, and we freshened the engine along with some porting and looks like the 461 has picked up some power, this combo is going in a true street car 65' GTO ...
... the engine is still on the dyno, as we will be testing 2 more sets of headers and a Demon carb, but we are waiting on some small parts to finish the testing ... 830 Holley Hyd. Roller (.562/.571)(248/254)(110 l/s) Torker II Doug's 1-7/8 Headers (with evac) 9 to 1 compression |
"...along with some porting..."
Info on the cylinder heads and port work involved ? .
![]() Quote:
(455HO Baseline) (A.P.D.'s 455HO Port) .100 - 82.4 .100 - 76.5 .200 - 153.2 .200 - 164.8 .300 - 201.8 .300 - 230.2 .400 - 230.3 .400 - 255.9 .500 - 240.5 .500 - 262.6 .600 - 242.6 .600 - 270.4 .700 - 244.4 .700 - 276.4 .800 - 247.5 .800 - 278.1 .900 - 249.2 .900 - 281.4 .950 - 250.0 .950 - 283.4 |
Incredible power for a 9-1 engine, very impressive.
Car Craft Garage. Automotive Restoration |
Very nice street motor!
That's a nice street/strip combo.
Nice work. |
VERY GOOD MATCH ON THE COMBINATION OF PARTS.
VERY HIGH END OF THE TYPICAL ASSUMED HP VS PORT FLOW/ENGINE PARTS MATCH Good job. Tom Vaught
thats pretty impressive!
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
Nice! Great numbers and build.
Nice to see old iron heads doin well... Nice power curve too... Mike will be enjoying this a bunch. It will be interesting to see what the header and carb changes do... keep us posted.
Nice numbers. I run a 9-1 TRW 455 HO engine. 10.96 @119mph in a 3500lb car.
Numbers should be close. Never dynoed it. Any guesses ? |
Wow, your numbers are kick azz. I'm hoping to get well into the 11's. Prior to Bill's work on my top end I ran 12.0's at last year. I was small on the carb, running a thirty year old 800 spread bore. My 1/8th mile ET's were in the 7.5's which should have got me at least 11.90's in the quarter. If all goes well I'll be on the local track [I-40] the end of this week. Other wise I'll be at the POCI /GTOAA co-vention.
Looking good Mike...Congrats once again!
LIKE. Appears the Roller cam spec'd is a way better match then my STREET/ "strip" combo below. Good job.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
What casting number heads were used?
Very nice!
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
This going back in the 65 Mike?
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
Nice build Bill, congrats
... thanks guys, we're pretty excited for Mike, hope to see it back on the track and running soon ...
![]() Quote:
... yeah, i'm anxious to see if my former Nascar SB2 headers are worth a poo, lol ... i'm hoping they work well, we're just waiting for the O2 sensor plugs, as these headers were built for 10 wide band sensors on BLP's acceleration dyno, and JMRE's only has 2 sensors, but they'll be here soon i'm sure ... |
