ign switch trunk lock
I have lost my car keys and would like to know how to change ignition switch and trunk lock without tearing anything up. I bought new key switch but can't remove the old one without putting the switch to the acc position. Can't locate the back portion of the switch that all of the wires connect to or I could replace the whole thing. Also, I have taken the back seat out and can't see the lock because I have a large air conditioner and extra transmission in there. Any help would be appreciated.
what year? I am sure someone on here has a switch for you.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
For the ignition switch, I'd pull the door trim off, remove the PASSENGER side door lock (the passenger side will have less wear than the drivers side lock), take the lock to a good locksmith and ask him to cut a key to work in the lock.
That should get your ignition key problem solved. For the trunk lock, get a trunk key off every GM owning buddy you have and simply try it. You might be surprised that with a bit of jiggling, it might unlock. If that doesn't work, all I can suggest if you can slide the items in the trunk to one side so you can get a suitable tool through the gap whereby you can grasp the flat tab and rotate it thereby unlocking the trunk. Final solution will be to drill out the lock barrell but that should be your absoloute LAST resort Good luck. Oh, and get a spare set of keys and put them somewhere safe in your house Ian
To laugh at men of sense is the privilege of fools. |
PHS it, that will have the key codes on it. The keys can be cut from that.
Mike
ign switch
Thanks for the replies. The car is a 65 Bonneville. The trunk key is in the body as opposed to the trunk lid. (they asked me that when I inquired at Auto Zone)
Can someone tell me how to PHS it? I didn't think they had the key codes that far back so I didn't persue the numbers route. Thanks again. |
Here's the link to Pontiac Historical Services: http://www.phs-online.com/ Also, as mentioned if you have any buddies with old GM cars, have them try their keys in both locks. You'd be surprised how often that works, they apparently didn't use very many different key patterns back then.
When I was a kid, one night my parents went out dancing with several other couples; my Dad had a '61 Catalina, and as it happened all the other people had Pontiacs as well. When they were leaving, one of the other couples discovered they'd locked their keys in their car. Just joking around, my dad stuck his key in the guy's door and it unlocked the car. Then, the other men tried their keys and every one of them worked as well. |
You could always make a bump key. Youtube probably has a 100 ways to make one!
It's hard to soar like an eagle, when you're surrounded by turkeys! My wife says she'd llike my car a lot more if it wasn't mine. 64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam. |
key
Remove the glove compartment lock & do the same as the door lock mentioned earlier. It's the same key for the glove box & trunk.
The PHS's I have on the 65's did NOT have the key codes on the billing history card.
65 Bonneville Brougham 4DHT 65 Grand Prix 2DHT......now parts 65 Catalina 2+2 2DHT 65 Catalina Safari 4DSW |
Heybuck that's a good idea on the ign lock.
And it gave me a good idea on the trunk. The glovebox uses the same key as the trunk, and only takes a few seconds to remove.
Actually, I can't claim the credit for the idea on pulling the door lock. A guy I know had some wife problems and she took his keys from his collector cars and threw them out. That's how he got his keys back. I must ask him if he used the glove box lock to get a new trunk lock key?? Cheers Ian
door opening
Easy enough to use a slim jim (not trans) to open the door on these models. If it is a hard top, or vert, a coat hanger will work, if the inside lock has a knob. Be careful around the rubber.
Remove the rear seat back and open the trunk with a screwdriver taped to a broomstick. A bright flashlight is needed. I have seen people use an oil dipstick to open trunk locks at the junkyard. The ignition bezel can be removed and a new switch, with key, is about 15 bucks. From there you need to get rekeyed or new locks. This time have a 3rd set of keys made, stash them somewhere. I ususally forget the secret spots anyway, but... Greg |
All three of mine have the key codes.
