Old 07-19-2013, 11:24 AM
Dave R's Avatar
Dave R Dave R is offline
Default Copying Factory Seam Sealer
Anyone know of an applicator that copies the factory technique? I'm not sure how they applied the seam sealer at the factory but it looks like a combo of squeeze tube and brush on?
Old 07-19-2013, 12:03 PM
Keith Seymore's Avatar
Correct - it was a pressurized applicator/wand that had a little bit of a brush on the end.
K
'63 LeMans Convertible
'63 Grand Prix
Old 07-19-2013, 12:12 PM
Dave R's Avatar
Do you know of any company that makes a similar one?
Old 07-19-2013, 12:49 PM
I do not; I could ask my buddies in the assembly plant if they have a name/contact for the style they are using now.
K
'63 Grand Prix
Old 07-19-2013, 12:52 PM
Dave R's Avatar
Thanks! I may have to try to fab something up. I'm trying to get it right for my 68 Firebird.
Old 07-19-2013, 01:28 PM
Best I can do on short notice:
This happens to be for spraying undercoating inside the door, but it would look something like this, if you can imagine the tip slightly flattened and with a short bristle brush on the end.
K
'63 Grand Prix
Old 07-19-2013, 01:30 PM
Dave R's Avatar
Wow! Cool Pic!
Old 07-19-2013, 01:32 PM
Originally Posted by Dave R View Post
Wow! Cool Pic!
I bet it's hot in there today!
K
'63 Grand Prix
Old 07-19-2013, 05:59 PM
Cammer-6 Cammer-6 is offline
I use the cheap throw away paint brushes and cut the bristles to about 1/2".
You can finger it in good then while still wet swipe the brush over it.
Some types can be rewet with lacquer thinner.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-19-2013, 09:12 PM
irgoatmike irgoatmike is offline
I've done what Cammer said to duplicate that OE look. Lay down your bead, tool it into seam with a finger and come behind it with an acid brush to duplicate the desired "brushed" look. Irgoatmike
Old 07-19-2013, 09:29 PM
zeebo's Avatar
zeebo zeebo is offline
what type of seam sealer product do you use? brand? i have some of the grey brush on type..works really well tho i dont get the factory look with a bondo applicator..i mostly use it to try and seal leaks in my car trunks....
Old 07-22-2013, 08:27 AM
LOL! I answered the question that was asked; you guys answered what it was he really wanted to know....
K
'63 Grand Prix
Old 07-22-2013, 12:17 PM
Dave R's Avatar
Thanks! The brush is a great idea. As for seam sealer, I'll probably use something from Eastwood or 3M (haven't bought it yet).
Old 07-26-2013, 11:18 PM
I like fusor 019 which can be applied direct to metal and tools nicely. It is a two component which keeps cracking, corrosion limited. Needs a special applicator gun though gets spendy. Irgoatmike
Old 07-28-2013, 07:41 PM
A large caulk gun modified with 2 pieces of PVC pipe as plungers will save you $$.
