Old 07-22-2013, 02:07 PM
1966geeto 1966geeto is offline
Default Floor Pan
Ok so this may be in the wrong forum sorry if it is .I am having an issue with 3-4 shift rod hitting the floor pan the linkage is the repro parts from Ames that came with the car. I have been slowly getting it together and Prev owner replaced the floor pan but it was lap welded in just before the shifter hole so far everything has lined up eng trans and cross member went right in z-bar lines up .I ordered the correct shift levers that attach to the trans and lined everything up according to the book it's a console car and all of the shifter is adjusted accordingly I'm out of ideas any help out there ?
66 gto 4spd
Old 07-26-2013, 01:56 PM
stone7777's Avatar
stone7777 stone7777 is offline
I had the same problem.
