car will not idle and has no power
I have a 66 gto with a carter afb 4034s. Changed the accelerator pump due to hard starting put everything back together and started. Found car started right up but fuel was coming out everywhere. I then removed top of carb and found that the needle valve seat faulty. Changed the faulty needle valve seat, set the floats per spec and installed top of carb. Measured accelerator pump clearance, checks good at .375. Started car and found that engine will not idle. Idle circuit of power circuit or both?
You may also want to post this in the Pontiac-Street section to solicit more responses.
I would verify that you do not have a large Vacuum Leak before tearing the carb apart again, if it will not run below something like 2000 rpm, you may have a leaking base plate gasket, or other leak. Just something to check before your tear into the carb again.
These are very difficult issues to T/S unless you are actually in front of the car.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
One more question, do you have spark at your points and are your plugs clean, not fouled or wet from cranking ? Good Luck Jax |
I don't know how much AFB info you have but this may be useful:
http://thefirstgensite.com/library/6...7S6BP29_43.pdf |
when you changed needle and seat, did you readjust the float level? Also, sometimes the little hangar that attaches to the needle will hang up the operation of the float. The hangar is supposed to pull the needle up as the float goes down.
